Author Topic: Air Con not cold tonite  (Read 48300 times)
Offline ket
  • Fat Ket
Re: Air Con not cold tonite
« Reply #20 on: April 04, 2008, 04:44:03 PM »
Try again today? Just now the weather is hot. Air con is cooling..  :thumbsup:
Like that mean is ok no problem with our aircon system.
Offline wave
  • i know i am kawaii.....
« Reply #21 on: April 04, 2008, 05:15:14 PM »
wha how come u all all set aircon around 24-25 one...
i set it as 23 for norm... then maybe increase fan speed if too warm...
cant help it... i think i have high body temp....
« Reply #22 on: April 05, 2008, 12:32:08 AM »
Yes, today back to normal.  ;D
Offline ket
  • Fat Ket
« Reply #23 on: April 05, 2008, 09:16:46 AM »
Cause you are a hot girl what. :yehyeh:
« Reply #24 on: April 06, 2008, 01:34:20 PM »
as long as outside whether is warm, our aircon will be cold. if cold outside then aircon will not be cold liao :(
« Reply #25 on: April 06, 2008, 01:34:37 PM »
Offline maverick1975
« Reply #26 on: April 06, 2008, 03:17:08 PM »
not sure about cold weather air con not cold..but today, weather so so HOT!!! and my aircon not cold!! i tune all the way to 18 and on all the way up and yet still not cold..stuck in jam even worse..then after that when reach carpark got shade, the aircon start to turn cold...goodness me.. my car is black FYI...
LaChio
« Reply #27 on: April 07, 2008, 01:19:51 AM »
Mine always set at 24 auto. Notice that aircon ok when on 'CLEAN' but not so cold when on 'ION'.
Offline ket
  • Fat Ket
« Reply #28 on: April 07, 2008, 07:45:02 AM »
Maybe black take more heat, than other colour. :smile:
« Reply #29 on: April 07, 2008, 11:00:47 AM »
Hi Bro, How to set "CLEAN" and "ION"?  Mine shows either "CLEAN" or "ION" by itself.  Which button to select "CLEAN" or "ION"?  Thanks.
« Reply #30 on: April 07, 2008, 11:11:14 AM »
I was going to ask this question too.  :D
Offline wave
« Reply #31 on: April 07, 2008, 12:44:06 PM »
i think it automatically switches mode from CLean to Ion...
read it somewhere on the manual...
Offline chwoo
« Reply #32 on: April 07, 2008, 01:28:39 PM »
Yah...cannot choose one.Usually will change to "ion" after 15 mins...
« Reply #33 on: April 08, 2008, 08:33:41 AM »
Thanks to all for the confirmation.  That's what I thought too.
Offline joyrob
« Reply #34 on: April 09, 2008, 10:59:41 PM »
but wat is the diff bet clean and ion ?
Offline carolyn
« Reply #35 on: April 10, 2008, 12:28:29 AM »
Ionizer is for purifying the air ma.. When they detect impurities in the air, the ionizer will turn on by itself rite.. then they will clean the air by charging dust and smoke particles into positive or negative ions so that they can stick to a charged surface.. Then can get rid of them..
Larger impure particles will totally fall out of the air when two smaller impure particles of different charges clump together..
So I think since it does ionic charging.. so heat is required to gain/lose the electrons to charge the particles ma.. So I think air con becomes hotter during ion mode?  :confused1:
But I think it is attached to our air con de.. so if on the air con.. it will be auto detecting if there's impurities.. So I dun think there's a way to turn it off w/o turning the air con off lei..
But I realise the ionizer often comes on only when I wind down window or open the door when the air con is turned on or when I fart in the car..  :bleh:
This 1 onli my theory hor.... I may be wrong...  :zipped:
We can never judge the lives of others, because only each person knows their own pain and renunciation. It's one thing to feel that you are on the right path, but it's another to think that yours is the only path.
« Reply #36 on: April 10, 2008, 07:25:19 AM »
hmm..... must check it next time i fart in my car  :bleh: hahaaaaaaa ;D
Offline leolooi
« Reply #37 on: April 10, 2008, 08:53:36 AM »
hahaha...dun over fart and let impurities come out as well  :bleh: :bleh:......
« Reply #38 on: April 10, 2008, 09:41:41 AM »
Don't overwork the ionizer.  Otherwise it sure breakdown.  Then you got to tell TCM that it is spoil because you fxxx.
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
« Reply #39 on: April 13, 2008, 09:55:19 AM »
just thinking aloud,
raining = poor visibility+ slippery = heavier traffic = slower speed. Heat trapped inside bonnet cant get flushed out due to start stop situations, heats up the aircon piping and voila, warmer air!
heh, dun flame me, not proven, jus thinking abit  :bleh:
hahah yeah yesireeeee!!! its because most of the warm air is coming from ur engine, hot engine = hot air coming in even on a very cold day ....good explaination ken
