Author Topic: Car Vibrates when Idling, anyone experienced?  (Read 42089 times)
syler
Re: Car Vibrates when Idling, anyone experienced?
« Reply #40 on: April 15, 2008, 12:17:55 PM »
boxer engine is a type of engine used in subaru, some wrx can hear the idling note from the boxer engine.. :) mabbe got chance u see vypez car..hehe  :bleh: i think most likely got the boxer note(sound) from the boxer engine..see his signature for telltale sign.. ;D
*box..box..box..box..box..box..*
« Last Edit: April 15, 2008, 12:22:07 PM by syler »
Offline hatch
« Reply #41 on: April 15, 2008, 10:47:29 PM »
for those wRX with loud idling note means that they had replaced with an unequal length extractor + (maybe) a cat back muffler.
Stock will never give that note.
Boxer engines not just confined to Subarus.
Some Posh and the older Alfa are on the same design.
Even the stock low growl is sweet.
i missed it.
Speeding has never killed anyone....suddenly becoming stationary is what kills you ---Jeremy Clarkson
Offline vypez
    • need help with words?
« Reply #42 on: April 16, 2008, 02:09:17 AM »
i missed it.
mmm..
just the extractor does give that sound, but its not pronounced.
works best with up,down,mid 3" pipes.
of course, having a unsilenced fujitsubo doesn't hurt.
« Last Edit: April 16, 2008, 02:18:58 AM by vypez [forgetful one] »
« Reply #43 on: May 05, 2008, 10:41:52 PM »
Hey Bro gracieg did you manange to get your car fix for the vibration issue? today my car also like that leh.. xiao xiao one..  :out:
Offline ckmckm
« Reply #44 on: May 05, 2008, 11:27:27 PM »
in technical point of view
it could be due to a lot of thing
it might be the petrol quality, might be your air filter dirty...
the above might cause your car to go siao siao.
anyone can share
Offline gracieg
« Reply #45 on: May 06, 2008, 06:05:22 PM »
sent to garage, reset idling level : no use.
sent to tcm, they claimed it's normal for such vibration  :mad:
in the end, GIVE UP. cause mine now is only mild vibration, but it gets bad when air con is off though.
« Reply #46 on: May 07, 2008, 09:24:37 AM »
Bro which workshop you went?
Offline gracieg
« Reply #47 on: May 07, 2008, 03:16:16 PM »
both own workshop and tcm ubi.
Offline alantan9
  • You'll Never Walk Alone
« Reply #48 on: June 03, 2008, 02:48:59 PM »
hmmz....mine also drops to 600 rpm sometimes n can feel the mild vibration....quite irritating haha. Any way to resolve this issue? I went back to TCM Ubi 2 times liao....they say reset my idling rpm to 750 rpm....still will drop to 600 sometimes. Can ask them to retune to 800 rpm? LOL
« Reply #49 on: June 03, 2008, 05:20:17 PM »
like tat ur consumption will be affected leh.
Offline alantan9
« Reply #50 on: June 03, 2008, 05:39:30 PM »
I just went back to TCM Ubi just now...requested for them to retune idling rpm to 800. Went on a test drive jus now felt ok no vibration nothing liao... I guess should be ok ba....750rpm and 800 rpm no much diff. On the highway, cruising at 80km/h at 1600 rpm. =)
Anyway i chatted with the technician just now and he told me that the ECU will readjust back one as in even though we increase the idling rpm by 50 or 100. Eventually it will readjust by itself after a few days. He did mention that it is normal for the idling rpm to drop once the aircon compressor is cut off.
Offline gh05tss
« Reply #51 on: June 03, 2008, 05:41:54 PM »
idling rpm low is good...esp if u always in a jam or travel often during rush hour ( like me )...downside , the car will 'shiver'.
Offline alantan9
« Reply #52 on: June 03, 2008, 07:54:33 PM »
Haha ya...but what i am rather irritated by the 'shivering'...haha... :bleh:
Offline liewks
« Reply #53 on: June 04, 2008, 10:55:44 AM »
Turn off the A/C and shift to N. Guaranteed 700rpm and smooth idling. I think that's what the ECU was designed to do.
Offline alantan9
« Reply #54 on: June 04, 2008, 11:20:01 AM »
hmmz....then like dat on and off the aircon abit no point leh...haha
Offline lsls
« Reply #55 on: June 07, 2008, 10:49:22 PM »
I sent back to tcm ubi , insisted them tune up to 800 rpm.
The old uncle initially refused, but i KPKB  . They tuned up 50 rpm to 800 rpm in at last.
No more virbrating now
Offline gh05tss
« Reply #56 on: June 07, 2008, 10:58:24 PM »
I solved my ride 'shivering' effect....simple
Volt stab....don't ask me why...when i put back my volt stab today, I didn't get that 'shiver' feeling while out driving.
Offline wooks
« Reply #57 on: June 08, 2008, 10:15:31 AM »
Open your bonnet when your rpm is at 600, you can see your whole engines is vibrating and any parts linking back to your body which caused this vibration.
So far my car was the air intake compartment that cause the problem, after tcm placed "cushioning", no vibration.
It linked back to your petrol used.  95 and 98 will make the difference.  Good tuning can also solve the vibration even if you use 92 and 95.  Sensitive drivers will feel the different petrol use and you step on your accerator.
« Reply #58 on: June 08, 2008, 09:00:54 PM »
Bro, which VS you fix? how you connected your VS huh?? did you connect direct to 2 battery terminals or after the current sensor?
I fix liao.. still will have leh..  :(
Offline gh05tss
« Reply #59 on: June 08, 2008, 09:17:07 PM »
Connect to battery, red to red, black to black.
