Author Topic: water in fuel tank  (Read 13101 times)
Offline jimmyng
water in fuel tank
« on: June 10, 2008, 10:47:11 AM »
dear all,
What things can be done if water got into fuel tank? Where to fix the problem? Any recommendation? Please advice.... Thanks
Jimmy
Offline ntihoe
Re: water in fuel tank
« Reply #1 on: June 10, 2008, 03:01:04 PM »
Not sure this make sense, water will evaporate by itself. Maybe, you can idle your car a couple of days and try starting your car. Or you can call TCM to check.
« Reply #2 on: June 10, 2008, 04:29:46 PM »
dear all,
Jimmy
Some petrol addictives can evaporate the water.  But that depends on the amount of water in your tank
« Reply #3 on: June 10, 2008, 05:35:22 PM »
petrol is less dense than water right? if water went in, will it sink to the bottom? if it does, then will water have the chance to evaporate since the petrol is floating on top of the water?
« Reply #4 on: June 10, 2008, 09:55:31 PM »
Think you've got to send the car to have your fuel tank flushed. How did it get there in the first place?
« Reply #5 on: June 10, 2008, 10:14:17 PM »
Curious to know how the water get in and how you know ?  :ohmy:
« Reply #6 on: June 11, 2008, 12:20:55 AM »
my guess: pumping petrol, spilled some, quickly take the water dispenser and pour off the petrol but forgot to cap back?
Offline xuan511
  • Latio is a good car
« Reply #7 on: June 11, 2008, 09:04:20 AM »
my guess: Mistook a water hose for a pump and stick it into the inlet.. den someone turn it on  :thumbsup:
Just Joking
Loving My Whitey
Offline jimmyng
« Reply #8 on: June 11, 2008, 11:03:07 AM »
hi guys.
Situation was like wat Carmodz says. Damn tired after work. Still got to pump petrol. So i eas in a semi conscious state. haiz... long story. was my ******** mistake. so nw muz clear up the mess. was afriad that my tank will rust, fuel hose stuck, engine piang! etc..... muz get it done fast. gotta waste 1 full tank of petrol!! bros pls help.....
jimmy
« Reply #9 on: June 11, 2008, 07:52:12 PM »
Carmodz, this really snd good, make sense coz i felt that before! but i didnt pour the water without cap open! Heng ah
« Reply #10 on: June 11, 2008, 07:53:41 PM »
hi guys.
Situation was like wat Carmodz says. Damn tired after work. Still got to pump petrol. So i eas in a semi conscious state. haiz... long story. was my s***** mistake. so nw muz clear up the mess. was afriad that my tank will rust, fuel hose stuck, engine piang! etc..... muz get it done fast. gotta waste 1 full tank of petrol!! bros pls help.....
jimmy
Call TCM for help? Better solution right?
If you need to pump petrol, you got to drive your car to the nearest station? By the time, any side effect for the fuel consumption during the journey? ??
« Reply #11 on: June 11, 2008, 09:30:55 PM »
I do not think our tank will rust so easily, there a coating I believe.  :smile:
