Author Topic: New Noise at Boot (Solution: WD40)  (Read 41157 times)
Re: New Noise at Boot
« Reply #20 on: July 14, 2008, 10:24:07 PM »
IF you guys are really piss with the sound, check your boot, there are 2 rods running across near the top with a piece of white plastic. When you open or close your boot, these 2 rods move and the plastic will twist causing the sound, go get some lithium grease and grease that place.
« Reply #21 on: July 14, 2008, 11:10:04 PM »
Hi dear all,
Regarding the noise, it is gone completely! after i spray WD40 to the joint areas just now, the noise is gone ... PRETTY!!!!
Regards.
« Reply #22 on: July 14, 2008, 11:11:16 PM »
Hi detach8, same issue with me too...used to hear the 'kok kok' sound wheneer I close the boot fast or slightly harder...my advice is don't rush to close your boot, do it slowly & you also wont knock into your instrument... ;)
Also...If there's some squeaking noise, should put some oil at the hinge...
darrylker,
after i spray wd40, i can close it 'fast fast' aso no noise....!!!
« Reply #23 on: July 15, 2008, 03:36:05 PM »
Fwah u guys give me the solution to my heart attack. ok tonight i go and "gor" some rc grade tamiya greese on that part.
« Reply #24 on: July 15, 2008, 03:44:25 PM »
hello detach8
why u Fme leh?
ya, u shld try. damn power. just spray and the noise gone. i can close it 'fast 'fast'. but open the boot, that tik tiak snd sure have one,but once only due to the "hook" area kua.
« Reply #25 on: July 15, 2008, 05:07:59 PM »
WD40 has endless uses.
You can even spray it on your paintwork to remove those irritating tar spots. Just spray on, wait for a minute and wipe off.
« Reply #26 on: July 15, 2008, 09:03:04 PM »
oh, so good.
just now i try again, really no noise...
« Reply #27 on: July 16, 2008, 12:46:04 PM »
Hi clarence
If spare on our latio? What's else can remove ah?
Will affect our paint also right?
Re: New Noise at Boot (Solution: WD40)
« Reply #28 on: July 16, 2008, 05:42:45 PM »
Confirmed will not affect paintwork as I have tried it before.
It also can make bird faeces easier to remove.
Once I had dried bird faeces on my window and as it had dried up, it left  a stain. I sprayed WD40 on my windscreen, let it absorb for 1 minute and just wipe it off lightly. The stain went off like magic.
« Last Edit: July 16, 2008, 05:45:22 PM by clarence »
« Reply #29 on: July 16, 2008, 06:02:15 PM »
oh. so good if it is real, then sui....
thanks for sharing.
i owe you once, where do u work? go lunch/dinner?
« Reply #30 on: July 17, 2008, 08:47:14 AM »
darrylker,
Hi Bro, I think this noise thingy was discussed before.  When I had that noise, I shifted the red plastic left/right till a spot where no more noise liao.  WD40 is easier.  Just spray is more straight forward.
« Reply #31 on: July 17, 2008, 12:50:26 PM »
hi humbercar
ya,iagree w u.
wd40 is much easier, spray and done. i dont want to shift the plastic left/right, coz the tcm guy put donno what 膏 (paste) to it when i complaint to them abt the noise since 1k servicing. it's so sticky. so, no touching, just spray will do (best).
regards.
« Reply #32 on: July 17, 2008, 01:11:14 PM »
clarence,
your PM is full.
« Reply #33 on: July 17, 2008, 07:22:55 PM »
darrylker,
Woah bro great job! Hmmm...I'll definitely use abit of wd40 to enjoy the shiok feeling of closing the boot smoothly... :D
« Reply #34 on: July 17, 2008, 10:36:37 PM »
darry
today, i try again. it is too smooth....! like using lubricant like that... very licin n smooth!!! worth to buy one!
Offline aerosignal
« Reply #35 on: July 17, 2008, 10:54:38 PM »
Actually, even better solution is to put some grease. Can buy lithium grease from bicycle shops. Most of the WD40 evaporates leaving a thin film which will be gone very soon and you will need to relube. Grease on the other hand stays around for a while. :thumbsup:
« Reply #36 on: July 17, 2008, 11:21:25 PM »
Yep, better to use grease instead of WD4D, dun forget all your 4 door hinges as well.  :D
« Reply #37 on: July 18, 2008, 01:10:34 PM »
Problem with grease is  that it attracts unnecessary dirt and dust.
« Reply #38 on: July 18, 2008, 01:44:39 PM »
hi aerosignal
regarding what u said.
now i remember, during my 1k servicing at tcm (bt), i complaint abt that noise. then they apply something on the 'red' plastic. i thk is what u said "grease", i donno what's that anyway.
BUT, it does't help me to solve the problem.
AND, WD40 solve it with just ONE SPRAY of effort!!! Go for WD40.
« Reply #39 on: July 18, 2008, 01:45:33 PM »
iagree with clarence.
that thing that tcm used made the 'red plastic' (and the "rod"? correct spelling? that 2 sticks of bar) to become very 'sticky'! i hate it.
