Author Topic: aircon colder after servicing  (Read 12291 times)
Offline wonglpnn
« on: August 14, 2008, 01:38:45 AM »
just to share: my aircon was quite erratic at times, with setting of 23oC, sometimes ok sometimes not, even during cool weather. found out that my compressor was running in & out quite frequently recently (about 1 time per minute), so during my 5k servicing this monday, i told the service advisor, and after that, my aircon now is running better, temp set at 25oC now also no problem. dunno wat they did, sure fix the problem. maybe car will run more efficient too?  :thumbsup:
if u can't convince urself,how u confuse others?
Re: aircon colder after servicing
« Reply #1 on: August 14, 2008, 04:31:26 AM »
What was done during the air con servicing to make it cooler and more efficient?  :smile:
« Reply #2 on: August 14, 2008, 07:16:26 AM »
can i check with the rest>> for our aircon>> we have 4 outlets (in general)..
but my 2 outlets (extreme left and extreme right) are very weak as compare to the center 2....
is this normal??
Offline wonglpnn
« Reply #3 on: August 14, 2008, 09:26:06 AM »
the customer service said "reset the controls"...when i probe further, she wasn't sure.  I can try to find out. i'm keen to know wat's done too. now i'm going 25/26oC on day time with 1 fan running.
Offline wonglpnn
« Reply #4 on: August 14, 2008, 09:33:53 AM »
is this normal??
side outlets are weaker than center ones too. i think is normal to be weaker coz center one is bigger, and for throwing to the back seats, but very weak, not sure. maybe u have closed the vent slightly?
« Reply #5 on: August 14, 2008, 10:25:24 AM »
hmm okie... i have checked liao.. i opened all the vent leh... ..
how weak ..... Its like>> for driver side, the extreme right outlet>> if i adjust till it faced my face>>> At level 1 blow power (1 fan), i dont think the cold air can reach  my face leh...
is this normal?
« Reply #6 on: August 14, 2008, 10:51:22 AM »
Did you all know that there is a 5th air con vent on the dashboard, just directly above the centre console?   ;)
« Reply #7 on: August 14, 2008, 06:06:00 PM »
i know abt it.. but i find it abit useless...... NOT strong + i cant put non-slip mat there as it will block air con  -__-
Offline wonglpnn
« Reply #8 on: August 14, 2008, 10:53:30 PM »
is this normal?
bro, it's same for me, so i think it's normal
« Reply #9 on: August 14, 2008, 10:55:17 PM »
Yes, it serves no purpose at all. I turned it off.
« Reply #10 on: August 15, 2008, 04:35:01 AM »
tat air vent on dash is for cold country when cold day the heater will warm the windscreen...
« Reply #11 on: August 15, 2008, 08:12:54 AM »
ahaha then CONFIRM + guarranttee.. useless liao haha
Offline aerosignal
« Reply #12 on: August 15, 2008, 09:56:20 AM »
Demister is on the front edge, right under the windscreen.
The center vent just above the radio is not angled to blow into the windscreen for demisting.
It is designed to "throw" air over the driver and passenger to the rear. I turned that vent off because I set my seat very high and the vent blows directly into my eyes.
« Reply #13 on: August 15, 2008, 09:58:47 AM »
You can adjust the vents' air flow to blow lower or higher so that it will not blow at your eyes.
Offline aerosignal
« Reply #14 on: August 15, 2008, 11:53:58 AM »
Only the ones by the side of the radio can adjust. The one on the top of the dashboard cannot adjsut one lah. Can only turn on and off. :thumbsup:
« Reply #15 on: August 15, 2008, 11:29:32 PM »
The vents on the centre console can be adjusted.
Offline totallypatrick
« Reply #16 on: August 15, 2008, 11:41:53 PM »
they just pump the gas loh.. during my 10k servicing i also complained not cold and they pump gas.. then 20k servcing came i "gei siao" say not cold again they just reset it. haha
« Reply #17 on: August 16, 2008, 11:53:12 PM »
huh? air con reset? aircon how to reset.. it's just a thermostat...
