Author Topic: Fuel Tank Checking at CheckPoint (Very Strict)  (Read 96399 times)
Re: Fuel Tank Checking at CheckPoint (Very Strict)
« Reply #40 on: August 14, 2008, 04:17:15 PM »
ic ic...
i used to station in KL b4..fabrication yard at klang...everyday drive between KL-Klang-Rawang...
Klang got very good tuner..
hi z
that's good.
tuner mean?
« Reply #41 on: August 14, 2008, 04:18:08 PM »
got one time the Today report , some sg car use a ram to tilt the car in order to pump more...
IMG!!!!
hi z
RAM? Memory?
what is IMG?
« Reply #42 on: August 14, 2008, 04:19:09 PM »
I was referring to the fuel pump in your Latio.  :smile:
If not how is your petrol going to flow if there is no pump? Cannot depend on gravity for petrol to flow out.  :D
hi clarence
i see. your knowledge abt car is good. i am a novice. i apologize.
i still don't know what is that.
« Reply #43 on: August 14, 2008, 04:20:29 PM »
bro,
for a fuel line system, we got fuel filter, fuel pump to transfer the fuel to the injector and those tubing for supply and return....sometime for those old car, the fuel filter needs to be change just like air/oil filter....
Aftermarket product like fuel regulator etc etc is to regulate the pressure of supply line...
hi z
that is too chim for me liao :(
thanks for your points.
Offline zzzz
« Reply #44 on: August 14, 2008, 04:23:03 PM »
hi z
RAM? Memory?
what is IMG?
whahaaa..
aplogies for my powderfool england...
Ram is the wood block to raise the car..
IMG is typo error...should be read as OMG !!! Oh..........My..........god........
Zzzz = z4
« Reply #45 on: August 14, 2008, 04:24:09 PM »
I second this information ... last week i just went in and had my tank filled to a 3/4 first, +/- 1 % from the gauge, then i pump another time to make sure that I have 3/4 after the traveling from SengKang to 2nd Link (woodlands jam from onemotoring)
the differences is only about another 12 dollars, which is about 5+litres
I usually will drive till reserve light up and  most of my fillup is about 38 litres
so technically we have about 7 litres of reserve but please bear in mind that the design usually have about 2 litres of buffer and our fuel pump will have difficulty draining the remaining 2 litres, thus we will be only able to travel for about another 4-5 litres.  ;D
but i seldom do that as I do not want to stop my car waiting for help ...  :pray:
Hi 553,
Question: Are you related to 883?
Just kidding.
Well, I don't think is worth to go JB to pump petrol then come back to SG.
Unless, you are going to Msia for a short trip, at least half to 1 2 days. Otherwise, it is not worth at all.
1) Jam when you go? Enjoy
2) Jam again when come back
3) 3/4 tank b4 you exit
4) Pump abt 1/2 tank before you back to sg (still worth?)
Msia inflation is much higher than SG, I believe for shopping, SG would still be offering the cheaper  price for most of the products.
My 20cents.
Regards.
« Reply #46 on: August 14, 2008, 04:25:45 PM »
whahaaa..
hi z
it's ok, my fault, not you.
i tot RAM = Random Access Memory mah. After you restart the computer, the things will be gone. Well, your RAM is wood block to raise the car.
OMG. Thanks for the clarification. You are a nice guy. :)
Offline zzzz
« Reply #47 on: August 14, 2008, 04:26:23 PM »
hi z
that's good.
tuner mean?
Tuner means the 2 radio "button" that an be tuned...kekekeke...
nah...tuner ...i was  referring to those car modification...eg piggyback, chip la..or ecu programming. those after heavy or ligh mod., they tune the ecu to suite those mod to give the  best optimun result..
cheer !
« Last Edit: August 14, 2008, 04:28:41 PM by zzzz »
Zzzz = z4
FP553
« Reply #48 on: August 14, 2008, 04:53:15 PM »
IMG!!!!
ya, remembered seeing that article ... anyway, they are trying to make sure the gas occupy the empty air trap at any corners ...
just think it is not worth going the extend to save the 1-2 dollars ... might as well spend those time into thinking of lo bang to make more money ... kekee :smile:
Offline zzzz
« Reply #49 on: August 14, 2008, 10:45:38 PM »
funny idea with funny ppl....
wat can i say ?
Zzzz = z4
« Reply #50 on: August 14, 2008, 11:04:21 PM »
wat can i say ?
hi z
iagree. just dun say anything ;) silent is golden.
btw, i just chk n pump tyres pressure. to 230 + 210.
going to KL 2molo afternoon 2pm.
already pumped $10 petrol (caltex,starcard@15%discnt) now it is above 3/4.
regards. :)
FP553
« Reply #51 on: August 14, 2008, 11:33:12 PM »
Hi 553,
Just kidding.
My 20cents.
Regards.
hahaa, bro ... apologize as i'm sqeezing too much informations into the same reply and thats might be the reason causing the misunderstanding ...
firstly, i'm not related to whatever ... 883 ... 1234567890 ...  :bleh:
and i too, agree, that just by going in to pump is not so worth for myself (not speaking for anyone else) as i dont enjoy the jam, thats why I frequent 2nd link even thou it is further ... mostly for business, makan sutra, meeting kakis, going for trips to kulai, genting, KL, Klang or even hatyai ... and also to clear carbon ...  ;D
Offline zzzz
« Reply #52 on: August 15, 2008, 08:22:26 AM »
hi z
regards. :)
bro,
enjoy your drive up ...
Starcard, if get the quotation from Viewerchoice, will up to 16 %...you wan to check it out...
Zzzz = z4
Offline aerosignal
« Reply #53 on: August 15, 2008, 09:34:58 AM »
50L? please recheck and confirm, I thought is 45L ...  :smile:
2nd that. 45L. Never pump more than 40L before. Even for the time I hit 710km. Only pump 39.xx liters only.
« Last Edit: August 15, 2008, 09:39:33 AM by aerosignal »
Offline zzzz
« Reply #54 on: August 15, 2008, 01:18:07 PM »
Wow,,...39 litre for 710 km..that is 18 km/l sia....
how u get it??
Zzzz = z4
FP553
« Reply #55 on: August 15, 2008, 03:00:44 PM »
@.@ 710km ... yesterday i just pump from reserve till full ... my mileage is 340km nia ...  :weep:
hahaa ...
Offline zzzz
« Reply #56 on: August 15, 2008, 04:52:56 PM »
hahaa ...
hahhaa
one solution for u...
donate your ICE as stated, properly weighting 1 ton, to me and your latio can fly...whhhhahaaaa
Zzzz = z4
« Reply #57 on: August 16, 2008, 04:24:06 PM »
hahaa ...
When my fuel needle hit the 1/4 mark, I already travelled 370km.
How come your mileage is so bad?
What are your travel habits?
Rev  a lot?
FP553
« Reply #58 on: August 17, 2008, 03:07:33 PM »
hahhaa
lol,
thats the point many ppl here are trying to relate to ... FC topic is subjecive, for me, is ok if my FC is within my acceptable range, dont wanna give up my ICE for FC, ICE more important to me ...  :bleh:
as for the 1 ton, i think the first to remove is myself ... weigh about 0.1 ton lor  ;D
FP553
« Reply #59 on: August 17, 2008, 03:14:16 PM »
Rev  a lot?
hmm ... yep ... i rev alot ... and my traveling is mostly city area, only 20% HW... the only problem is i though with my driving habit, latio can help to minimise the useage, but ...
my wife say if i drive latio also only 300 - 400, might as well drive a rex or MPV ...  :D
anyway, just went to JB yesterday with my friend to bridal shop, then eat and jalan jalan ... i pump full to go in but never check ...   :glare:
