Author Topic: Optimum Air Con Temp Setting  (Read 55076 times)
« on: August 21, 2008, 12:31:17 AM »
What temperature do you set your Latio air con thermostat?
I set mine at 24 degrees but find it really stuffy as most of the time it is room temperature air coming out from teh vents.
Only when I set it to 23 degrees does cold air come out for a longer period.
Re: Optimum Air Con Temp Setting
« Reply #1 on: August 21, 2008, 08:10:28 AM »
I had been using 25 / 26 for the last 2 yrs plus.  It works well and quite cooling except on rainy days where the temperature outside is cold.
Offline HM76
« Reply #2 on: August 21, 2008, 09:15:35 AM »
always on 25deg at step 1/2 for the past 10mths, so far so good...
Regards,
HM76 (laihm76)
Offline fickle
« Reply #3 on: August 21, 2008, 02:14:27 PM »
my a/c most times 22... hot day 19. night rainy maybe 23..
Offline nick3288
« Reply #4 on: August 21, 2008, 02:27:17 PM »
for me most of the time 25.. only on some extreme hot day set to 24/23..  usually use manual blower set to 2 bar.. auto blower is too strong at starting and too low after reach the pre-set temp... so will feel stuffy.. ;)
""" Song song till Jurong """
« Reply #5 on: August 21, 2008, 05:33:26 PM »
mine is normally 25. only hot weather then 22/ 23.
Offline hope_n_pray
« Reply #6 on: August 22, 2008, 08:47:57 PM »
Mine is 23 or 24 depending on the weather. But my dad always puts much lower..
Offline Cheong
« Reply #7 on: August 22, 2008, 09:27:11 PM »
Most of the time 26 degree............ :cool2:
Set at 25 too cold liao .............
sometimes i even set 27 when cold..... :D
What Did Not Kill Me, Makes Me Stronger.
Offline petra74
« Reply #8 on: August 23, 2008, 11:08:31 PM »
Mine is mostly 23 or 24.... I believe outside temp does affect how fast the aircon really kick in. Like today, early in the morning, rain heavily, air con cool very fast....
"... for King and Kingdom..."
« Reply #9 on: August 24, 2008, 12:35:55 AM »
I experienced the opposite.  During hot days, set at 24 degree can feel the cold air.  When raining days, get warm air if set at 24 degree.  So got to set lower on raining days.  Air-con try to be smart and compensate with auto climate control, but overdo it.
Offline rodrigue
« Reply #10 on: August 24, 2008, 09:11:46 AM »
yeah agree ur point on the ******** AI aircon control, I'm always on 25 deg unless hot day then i set to 22. However, i'd encounter several times - either at night when it's cold or raining days, the air seems to be warmer than the atmosphere outside and u can really feel it's like warm air. Guessed quite a few pple here experienced the same too..
Offline wave
  • i know i am kawaii.....
« Reply #11 on: August 24, 2008, 03:27:53 PM »
usually set to 24 or 23... with fan blow at 1 or 2....
« Reply #12 on: August 24, 2008, 05:26:51 PM »
set at 23C all the way no matter weather hot sunny cold rainy snow or stormy...
Latio air-con if 25 & above feels juz like my house fan blowin totally hot & stuffy
Y like dat ah? i sit my fren altis hot sunny aftnoon he set 27C very fast cool oledi
« Reply #13 on: August 24, 2008, 08:53:35 PM »
Maybe your air con compressor is faulty?
Faster go back to Tan Chong to get free replacement during warranty.
Offline bluesmurf
« Reply #14 on: August 25, 2008, 08:31:45 PM »
I always set my a/c at 28 for normal weather, 25 or 26 at fan 2 when it is damn hot. I experienced a/c not cold when i first collect my car, after i told them the issue during my 1k servicing, my a/c been in tip top condition for past 1 year. I would recommend you guys to tell TCM of your car a/c issue.
Life Is FuLL Of Surprises! You n3v3 kNow wHat you geTTing n3xt!
Offline AMG
« Reply #15 on: August 25, 2008, 10:40:50 PM »
There was once when i felt my a/c not feeling cold at 24. Didn't bother until 5k servicing and when collect car, found the a/c has been re-set to 27 by TCM. Quite surprise to find 27 quite cold during the night but not day time. Adjusted a/c to 25 the next day and it has since been serving me well for the past 3 months. The next time you go for servicing, can try to set it 24 or lower and tell them a/c not cold. They will rectify for you.
Offline liewks
« Reply #16 on: August 27, 2008, 11:06:31 PM »
I think Nissan has a "weird" air-con adjustment algorithm. There are temperature sensors just under and slightly to the left of the steering wheel. And an "external" sensor near the windscreen.
Say you set 26C. On a hot day, that 26C will make the aircon compressor compensate by running the compressor much harder because the "external" sensor thinks "boy it's a really hot day".
On a cool day, the "external" sensor says "I don't really think he wants cold air right now" and runs the compressor under light load. The internal sensor thinks the temperature is just fine because it is located lower down where cold air sinks.
« Reply #17 on: August 28, 2008, 08:58:13 AM »
Maybe you can place a piece of aluminium foil over the air con sensor on the dashboard to overcome this issue.
Offline leolooi
« Reply #18 on: August 28, 2008, 10:24:50 AM »
mine always 26 on normal day, 23 on hot day, blowing at level 1.... :yehyeh:
Offline pseudo
« Reply #19 on: September 09, 2008, 12:07:19 AM »
mine is usually at 25 on normal days, super hot days would lower to 22. i remember before my 1k servicing my a/c cools really slowly and i told TC about the problem. think they did do sth about it as after the servicing my a/c has been serving me so well that my front passenger will complain that it is too cold even on 25 on normal days.
