Author Topic: Water circulation sound  (Read 13892 times)
Offline fineLatio
« on: August 31, 2008, 01:12:09 AM »
when i start engine, i can hear Water circulation sound somewhere near the gear box. normal? last time dun hv such sound.
Re: Water circulation sound
« Reply #1 on: September 01, 2008, 10:55:37 AM »
If your Latio is under warranty, send it in to Tan Chong, but I highly suspect they will tell that "Nothing is wrong."
Offline baobao
« Reply #2 on: September 01, 2008, 04:53:33 PM »
My new ride got a hissing sound from the console.. sound like gas leaking..  dunno whats wrong?  :crycry:
Offline Keromond
« Reply #3 on: September 01, 2008, 07:40:35 PM »
Baobao....when u going for ur 1k servicing>
« Reply #4 on: September 01, 2008, 08:51:45 PM »
hi!
the sound come out when u turn on aircon, rite? if so, i m having this sound oso. think is the pump pumping the refrigerant.
« Reply #5 on: September 02, 2008, 12:04:53 AM »
if it is the hissing it is normal rah.. that is the aircon sound. even home aircon also will have that sound. mai kan cheong, just ask the SA if you are concerned.
Offline baobao
« Reply #6 on: September 02, 2008, 12:05:43 PM »
hi!
The sound can be heard during the whole journey le.. my old kia air-con got no such sound before le..
now at the service center waiting for check up.
« Reply #7 on: September 02, 2008, 03:12:09 PM »
if keep hissing means lao gas liao... need to top up or aircon leak. if leak.. sian!
« Reply #8 on: September 02, 2008, 05:02:57 PM »
Why is Latio air con so special?
When I turn on aircon, the PSSSSSSTTTTTT sound comes on so loud. Other Jap cars don't have this sound.
Offline baobao
« Reply #9 on: September 02, 2008, 06:39:19 PM »
This is the hissing or PSSSSSSSSSSTTTTTTTTTT sound i heard. Lucky they managed to solve it.
They changed 2 'O' rings and tightened the valve. I tested and really no more hissing sound. :)
« Reply #10 on: September 02, 2008, 08:27:52 PM »
So you mean when I turn on air con, the PSSSSTTTTT sound should not be so loud?
There is a problem with my Latio?
Offline wave
  • i know i am kawaii.....
« Reply #11 on: September 03, 2008, 01:55:11 AM »
normally if i start engine with aircon on, the sound is pretty obvious... tried starting without aircon and no sound at all....
also tried warming engine liao then start aircon.... the sound not that loud liao...
weird.... i will highlight this issue during my 20k svc.....
« Reply #12 on: September 03, 2008, 10:30:59 AM »
hi bao2
i thk when we 1st turn on the aircon, it surely have abit of that kind of noise?
« Reply #13 on: September 03, 2008, 12:23:47 PM »
hi bao2
Thought is normal for Latio ?  :blink:
« Reply #14 on: September 03, 2008, 02:26:15 PM »
dunno leh i drive quite a few cars before all ish like that. jap car, european car. all same. the sound is only in the beginning, after that gone liao.
Offline baobao
« Reply #15 on: September 03, 2008, 03:11:39 PM »
My problem with the sound is that its always there all the time from pt A to pt B.
lucky now better liao  :smile:
Offline twelfth
    • pictures
« Reply #16 on: September 13, 2008, 11:08:03 PM »
dont think so leh i went to book service slot for some issue
-   CHECK VEHICLE NO POWER-ECCS CONSULT & TUNE UP  request them to help as i change to 16' rim so far no different
-   CHECK VEHICLE HIGH FUEL CONSUMPTION-TUNE UP   same as above so far no different
-   CHECK AIRCON LOUD HISSING NOISE WHEN START AIRCON -RENEW COOLING COIL & THERMO SENSOR-VACUUM/TOP GAS issue resolved, when cold start a very short & soft hissing sound.
-   CHECK REAR TRUNK KNOCKING NOISE WHEN CLOSE -INSULTAE REAR NO.PLATE issue resolved, it feels more "heavier" when closing, no more sound.
Zoom first talk later
