Author Topic: Latio not as good as mention.....  (Read 334553 times)
« Reply #380 on: November 05, 2008, 01:28:47 PM »
Again curious are you old enough to drive or just a kid hide behind the monitor as a phantom web surfer having fun as a PCW. Do you really have knowledge of cars ?
To answer your question, spare tyre regardless of age is not meant for normal usage, it just an aid for you to get to the nearest tyre shop to repair your normal tyre, that how the spare tyre come about ?
Now quit spouting about the tyre exposing to heat and so fore, build up your knowledge before getting members here who are actually drivers to get hurt with your comments. Wake up kid. Sorry for being straight.
Dun have to be so hostile bro, the manual did state that tyre rotation is recommended at every 10k, including spare tyre, so its true that the spare tyre can be use. But of course, provided you didn't upgrade to bigger rims  :smile:
As for me, I am actually thinking of removing my spare tyre so yup, my spare tyre is only for driving me to the next tyre shop in case of emergency, touch wood :bleh:
« Reply #381 on: November 05, 2008, 04:33:02 PM »
Dear forummers,
it is ok to discuss, exchange ideas and opinions. It won't be good to share wrong info, yes that i agree, but then again, that's where the others who know their can add in what they know to make right what's wrong. Herewith, discussions can take place, and forum interactivity levels will improve.
It is however, not quite acceptable to be personal. It might scare off others who would like to share, but scared of sharing due to personal attacks that may occur after he or she makes a post.
Let's try our best to be objective and neutral in our posts shall we? If any post or reply is wrong, pse correct the wrong, but in a diplomatic way. I certainly won't want to see TLC going thru online flamming again and then the moderators receive PMs about the situation.
Your co-operation is sought.
« Reply #382 on: November 05, 2008, 06:22:48 PM »
I wish I have the full size spare tyre. Mine is smaller temp spare tyre, compartment can't fit a full size.  :(
*mine is 2005 model
Offline MadMatty
« Reply #383 on: November 05, 2008, 08:46:35 PM »
u change 1 pc only.
stamford only have falken and Continental
I used the Falken as the spare...if change both for the front wah big hole in pocket :crycry:
Offline MadMatty
« Reply #384 on: November 05, 2008, 08:48:37 PM »
never go to stamford to change tires their price are out to chop carrot 1 :nonod: why dun u use ur spare tire?
kena the nail at a spot where repair would be useless....so bo pian have to change a new one....wanted to go to my regular tire shop but no time so bo pian end up with stamford...
Offline MadMatty
« Reply #385 on: November 05, 2008, 08:49:50 PM »
You should have used your spare tyre, since your car is only 3 mth old and tyre wear on other tyres are minimal.
If you changed only 1 tyre, it is dangerous to use different brand with different tyre thread pattern on the same axle.
Tyres should be ideally be replaced in pairs, of similar brand and model no.
yeah that why i decided to use the falken as spare....maybe later stage change both front to the same make...
Offline MadMatty
« Reply #386 on: November 05, 2008, 08:51:54 PM »
yeah i heard about that too....but apparently my spare is the same regular tire as the others that are fitted on the car....
« Reply #387 on: November 05, 2008, 11:12:05 PM »
*mine is 2005 model
don't worry bro Ying, u r not alone...me too, yr 2005, Jul ;)
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
« Reply #388 on: November 06, 2008, 06:18:38 PM »
wat u mean by full size???u mean ur spare tyre is smaller then the actual wheels u r using now???wierd leh
« Reply #389 on: November 06, 2008, 06:22:47 PM »
yeap, and have to drive slow when using it. not wierd, I saw other car also using this type, lighter mah.
Offline Keromond
« Reply #390 on: November 07, 2008, 12:43:35 AM »
HI all,
side track abit ar, but still something to do with LAtio not so good issues.. nowadays, when ever I go over some small hump...the vehicle will sway to left or right automatically... is it becos of balancing, alignment? it just happens n I realise my steering wheel like getting lighter...anyone else also have ar?  :(
