Author Topic: Driver side door  (Read 17893 times)
Offline Latio77
  • I love my Latio sport!!!!!
Driver side door
« on: October 12, 2008, 02:49:11 PM »
Hi All, have anyone got this problem, when u close the driver side door.. the sound look different from the other doors. wheather isst the rubber is harden or close freq .. or issit the door is lighter???? it dun give u the smooth sound when u r closing.
Re: Driver side door
« Reply #1 on: October 12, 2008, 04:01:15 PM »
The sound looks 'hollow'? Mine is minor.
Offline sam
« Reply #2 on: October 12, 2008, 04:36:40 PM »
Dont worry, all jap cars in this catg r the same.....just do up sound-proofing .. kill 2 birds with 1 stone.;; will be quiet like Lexus.
« Reply #3 on: October 12, 2008, 05:15:39 PM »
One thing I don't like sound-proofing is that, u got to dismantle all most ur entire door, with such new car, heart pain leh.
Offline sam
« Reply #4 on: October 12, 2008, 08:30:41 PM »
change the stock speakers as well, they just take off the front panel, clip on clip off operation only ( NOT THE WHOLE DOOR that seious ). taking out that panel just takes 2 minutes.. no heart pain. With new component speakers installed.. wah .. sound different.. just like in a mini concert after the sound-proofing. Sound quality On par with our 2 Durians.
« Reply #5 on: October 12, 2008, 09:45:10 PM »
same. too bad, due to low frequency is too strong, my passenger door side trembles quite a lot. Maybe I should invest a small woofer which that will not over stress my alpine speaker too much. hee
« Reply #6 on: October 12, 2008, 10:41:10 PM »
Our stock speaker is also from JVC leh. No good ?
« Reply #7 on: October 12, 2008, 11:48:38 PM »
Head unit is from JVC but I am not sure if speakers are from JVC too.
« Reply #8 on: October 12, 2008, 11:59:31 PM »
Go and open up and see for yourself if you are driving one.
« Reply #9 on: October 13, 2008, 12:03:14 AM »
Where can do sound proofing so that Latio can be quiet like Lexus?
« Reply #10 on: October 13, 2008, 12:05:37 AM »
Bro, don't think you can soundproofed till Lexus level bah.  :D
« Reply #11 on: October 13, 2008, 12:07:02 AM »
I think your Latio will drink like a Lexus after the added weight from all the sound proofing.   :bleh:   ;D
Latio can NEVER achieve the kind of quietness in its cabin. Latio engine is noisier and neds to work harder as it is less than 1/2 of Lexus engine capacity.
Latio glass is also thinner than Lexus, so traffic noise can still filter in thru the glass.
Offline Latio77
« Reply #12 on: October 13, 2008, 02:10:35 AM »
Hi not the speakers or soundproofing matter..... :nonod: :nonod:
I mean when u close the door ,it louder than the passenger door ..
I think it the door insulating rubber not good or wat???????? :confused1:
« Reply #13 on: October 13, 2008, 08:07:07 AM »
It should be the same, did you try sitting on the passenger side and close the door ?  ;)
Second possibilty is our driver side may tend to wear and tear fast due to the frequency of usage.
« Reply #14 on: October 13, 2008, 10:37:10 AM »
you pull too hard with your right hand is it?
Offline Latio77
« Reply #15 on: October 13, 2008, 03:41:49 PM »
Hi jass, i also think that too, maybe it the rubber seal no good or possibilty is our driver side may tend to wear and tear fast due to the frequency of usage. The sound look like hollow type???? :unsure: :unsure:
Maybe go servicing, than ask the mechanic to check......... Thank for the  infor........
Offline sam
« Reply #16 on: October 13, 2008, 09:09:58 PM »
Bro... fret not whether it is the seal, gasket, etc.. our doors are REALLY HOLLOW ( wait till you open the panel , u can understand).Soundproofing by adding on 1 or 2 layers does really helps in 'reinforcing' the door and improves on sound quality too. The stock speakers are paper-cone type which cannot take 'HEAVY' or BASS-ful blast,. that's y i recommend change to mid-class components speakers ( or high-end type if you can afford ). Yes I agree fully with some brothers that Latio / Lexus is from 2 different worlds... but at least we can enjoy the quietness as compare with other Jap/Thai SAME CATG. The s/p materials weight is inmaterial. Wat's is another few kilos added to achieve the satisfction all-round.
once a Lexus ahmad driver
Offline Latio77
« Reply #17 on: October 13, 2008, 10:55:12 PM »
Bro Sam, so any idea where to install soundproof that is not expensive and good quality??????
As for the sound system, i understand that the normal speakers is not so good.........
but i dun intend to spend so much money on ICE system......
Offline sam
« Reply #18 on: October 14, 2008, 10:14:56 AM »
Bro Latio77,, Mine done  ( 4 doors * single layer only + wheel arch cos $ not enough ) Vpex ( THE FORGETFUL ONE ) at Toh guan centre. you may contact him, 1 of the forumers here... maybe now he has promotion. cheers
JUST DO IT.
Offline Latio77
« Reply #19 on: October 14, 2008, 10:38:38 AM »
JUST DO IT.
Bro Sam, Thank for your Info... :smile:
if i want to do , I may contact Vpex..
Cheer ::)
