Author Topic: Where to find colour code information?  (Read 23578 times)
« on: October 20, 2008, 12:01:18 PM »
Hey guys
May I check with where could I locate the colour code of my car? Would like to ensure that the "complimentary" touchup paint matches.
Anyone use the "complimentary" touchup paint before? Is it good?
Last Sat, my (DS3)spoiler kenna hit by pebble(s); now got a rather deep scratch.
Tks =)
Rgds
Alan
« Last Edit: October 20, 2008, 12:03:39 PM by alangohek »
Offline Indignant
Re: Where to find colour code information?
« Reply #1 on: October 20, 2008, 12:37:08 PM »
Yo! Under the bonnet.  :D
« Reply #2 on: October 20, 2008, 12:51:55 PM »
Alan,
You can also use the touch paint found in your car.
If you can, I rather you touch it up yourself.
My freind's Sylphy was very badly touched by Tan Chong. It's a free service so cannot expect much. Worst case scenario if the surface is not properly cleaned to prepare for touching up.
First, make sur eteh area to be toucheed is clean
Next, use cleaner wax to gently wipe it over the area to remove any surface dirt embedded in your paintwork
Finally, you can use touch up paint to touch it up.   :smile:
« Reply #3 on: October 20, 2008, 02:00:57 PM »
Alan,
Thanks Clarence =)
I guess the last step is apply wax then sealant when the paint is dry right?
« Reply #4 on: October 20, 2008, 02:17:08 PM »
There is no need to apply sealant or wax after the touch up paint has dried.
In fact, you should not apply wax or sealant on the newly touched up area until the paint has fully cured.
« Reply #5 on: October 20, 2008, 02:20:40 PM »
Noted and thanks =)
« Reply #6 on: October 20, 2008, 10:28:49 PM »
Thanks Clarence =)
It's sealant before the wax.. Wax is the last step.
« Reply #7 on: October 21, 2008, 10:00:29 AM »
Just to clarify .. Pls correct me if I am wrong. Thanks =)
1) for touch up works is apply sealant and then wax after the paint has cured and dried with the original paintwork.
2) But for normal circumstance (after car wash), is apply wax then sealant.
« Reply #8 on: October 21, 2008, 10:02:22 AM »
Hi Indignant,
I can't seem to find it leh. The numbers that I found does not include the color code.
Rgds
Alan
Offline jpgyip
  • ICE juz personal preferance towards great music
« Reply #9 on: October 21, 2008, 10:28:28 AM »
Bro for Amethyst Gray is L60. Open ur bonnet and look somewhere near the firewall at the driver side u will see a metal plate with the color code.
« Reply #10 on: October 21, 2008, 10:35:12 AM »
Alan,
where?
Offline jpgyip
« Reply #11 on: October 21, 2008, 11:33:24 AM »
where?
U can actually get it free from ur SE. I got mine from my SE.
« Reply #12 on: October 21, 2008, 12:01:33 PM »
Regardless whatever step. It's sealant first than wax. Wax always last... But you have to wait at least 2 hours, or better one full day for sealant to cure 1st then you wax.
« Reply #13 on: October 21, 2008, 12:49:44 PM »
Can you explain the logic on why we apply sealant first, before applying wax?
I thought sealant is the final step - to seal in the wax and offer protective layer.
« Reply #14 on: October 21, 2008, 01:23:42 PM »
Sealant won't stick to the wax...
Basic detailing is wash->polish->seal->maybe wax if you still ahve energy.
« Last Edit: October 21, 2008, 01:36:52 PM by Ender »
« Reply #15 on: October 21, 2008, 03:19:29 PM »
You can find it in the glove box. Was told that it comes from Japan and together with the vehicle.
where?
« Reply #16 on: October 21, 2008, 03:21:54 PM »
Ok, saw it. Saw the print "L60" with other letters numbers.
« Reply #17 on: October 21, 2008, 03:28:38 PM »
Alan,
When I called up TCM up to check whether the touch up paint is meant for my car, they are not able to confirm. They suggest me to bring it down for them to touch up FOC. So I did so at Ubi. Friendly with the uncle, quite satisfied with the job done. Now the mark is less obvious.
By the way, I was told by the uncle that we could use the touch up paint that comes with the car if it shows no sign of drying up. But we have to shake it really well to minimize the color difference from original paint.
« Reply #18 on: October 22, 2008, 09:46:36 AM »
I don't see any in my glove box.....
« Reply #19 on: October 22, 2008, 09:25:14 PM »
Most probably your SE did not give it to you lor.
