Author Topic: Blue Engine Oil Indicator Light  (Read 33882 times)
Offline SC_New
« on: October 21, 2008, 10:26:00 AM »
When starting my car (Latio/Sedan/Premium) every morning notice there is one blue engine oil light. The manual says it lights up when engine oil is cold. Usually I idle for a few minutes on 'Park'  for the blue light to go off before putting the car on 'Drive'. Is it necessary to wait?
Jo_Lee
Re: Blue Engine Oil Indicator Light
« Reply #1 on: October 21, 2008, 10:41:33 AM »
usually we will wait till the blue light is off b4 we move off...but some of us here will move off slowly with the blue light on and
pick up speed once the blue light is gone.
not so good for the engine in the long run if u keep driving off with a cold engine.
« Last Edit: October 21, 2008, 10:43:06 AM by Jo_Lee »
« Reply #2 on: October 21, 2008, 10:43:52 AM »
Hi SC
Relax.
It is normal. It takes abt 1 to 2min for the Engine to warm up before you start to drive.
But usually, when I see the RPM drop to abt 1200rpm (the blue light still on), I can start to drive liao but drive at SLOW SPEED until the blue light is off.
« Reply #3 on: October 21, 2008, 10:58:57 AM »
You only need to be seriously alarm if the same logo comes out in red...it means engine overheat....might explode and catch fire if u dun stop the car and turn off the engine....
« Reply #4 on: October 21, 2008, 11:00:29 AM »
i think its a different logo.
its red, but higher in position.
i know, i kenna overheat because my fanbelt shredded into 3 parts b4..
« Reply #5 on: October 21, 2008, 11:12:55 AM »
Is it a different logo?? Tot i saw tat it is the same logo but different colour in the User Manual...
How did u get it overheat? Had never driven a car until it is overheat...cost a lot of $$$ to replace the fanbelt?
Offline HM76
« Reply #6 on: October 21, 2008, 11:28:05 AM »
usually i also wait for the blue light to goes off then drive off...  i suppose that is the temperature rite...  usually it will goes off around 1K or 900 rpm
if really need, dun on the aircon first if you were to drive off with the blue light on
my personal preference...  :bleh:
Regards,
HM76 (laihm76)
Jo_Lee
« Reply #7 on: October 21, 2008, 12:13:56 PM »
sounds serious boy :ohmy: is it due to normal wear & tear or u wreck yr ride ?  :devil2:
« Reply #8 on: October 21, 2008, 12:16:04 PM »
Hi burnolise
iagree with you.
if we see 'red' light appeared, we must stop the car asap & chk it out.
Offline david1881
« Reply #9 on: October 21, 2008, 12:19:29 PM »
Without the fan belt, the water pump won't be functioning.  Overheating will be expected.  Battery will be the next to go flat as alternator is also not working to re-charge the battery.
« Reply #10 on: October 21, 2008, 12:47:24 PM »
Hi burnolise
iagree with you.
The problem without a temperature gauge is when the red light bulb indicating obverheating, blows without us knowing.
« Reply #11 on: October 21, 2008, 12:52:56 PM »
nope, the bulk of the $ was on the towing. the fan belt was replaced free by the workshop (Chip Soon @ Tampines Industrial Park) because prior to the shredding, they installed a new fanbelt. but sad to say, that fanbelt either isnt of good quality, or they had tighten too much.
« Reply #12 on: October 21, 2008, 12:55:05 PM »
i think its due to abnormal wear and tear
« Reply #13 on: October 21, 2008, 12:57:05 PM »
yes, hence such, it may be a good idea to have a gauge or some sensor to display the water temp.
according to my overheating experience, the engine overheat check light comes on when the water temp hits 105 degrees celcius
« Reply #14 on: October 21, 2008, 01:59:16 PM »
wah...tat sound dangerous man....hmm....when i first got the car did felt tat some display is missing from the panel...took me a while to realise tat it is the temp guage....
« Reply #15 on: October 21, 2008, 02:06:32 PM »
i check before with my se, she say nissan cars seldom have over heat problem
« Reply #16 on: October 21, 2008, 02:33:21 PM »
Seldom != Never.......saw on straits times internet...some guy saw many cars stalled b'cos overheat after stuck in custom jam for more than 3 hrs.....
Offline sam
« Reply #17 on: October 21, 2008, 05:14:20 PM »
To be on the safe side ( prevention is better than cure ), i installed the voltage & temp gauges.  :thumbup:
« Reply #18 on: October 21, 2008, 05:23:01 PM »
Where the gauges located? It will be sticking out as extra "clock" from ur dashboard right?
Offline sam
« Reply #19 on: October 21, 2008, 05:30:42 PM »
on the A pillar ....  or u can choose to mount it under the HU unit , regretted which i never did.
