Singapore Nissan Owners Group
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Login
Register
Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners
Latio
how the sports mode work???
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: how the sports mode work??? (Read 10297 times)
lonhong
Idling (800 rpm)
on:
November 05, 2008, 09:06:14 AM »
Hi guys,
first time driving the auto car, would like to check with you guys how the sports mode / od works? is it detrimental to the gear if i were to switch around the modes when my rpm is relatively high as i floor the accelerator?
Logged
dsrio
Administrator
Mid Zone (3000 rpm)
Car Color: Black
Re: how the sports mode work???
Reply #1 on:
November 05, 2008, 09:26:26 AM »
mine is cvt, so when i press sports mode, rpm shoots up, but i think u must already be at certain speed then can feel the different, i ever tried after moving from stop immediately press sports mode, machiam like no use leh, juz roar roar only
Logged
lonhong
Idling (800 rpm)
Reply #2 on:
November 05, 2008, 10:06:59 AM »
but exactly how it works lei??? any technical description?
but last night i floor... now heart really aches... cos my car covered 4400+km only...
Logged
clarence
Max Torque (4400 rpm)
Reply #3 on:
November 05, 2008, 10:15:29 AM »
Your Latio Sports model has an identical engine and gearbox as the cheaper sedan model.
Only difference is the body kit and accessories.
Sports mode means OD Off (Overdrive Off), so your car is using only 3 gears instead of 4 when OD is turned on.
The OD switch is at the side of your gear lever.
To avoid unnecessary or premature wear and tear to your gearbox, when overtaking, just depress your accelerator all the eway to the end and your gearbox will auto kickdown.
You will also see your rpm going up.
It is not necessary to switch gears.
Logged
lonhong
Idling (800 rpm)
Reply #4 on:
November 05, 2008, 10:28:18 AM »
oh ok... i get what you mean... so the od is somewhat like down 1 gear with u already at cruise gear... thanks.
Logged
clarence
Reply #5 on:
November 05, 2008, 11:59:35 AM »
Yes.
So with OD off (orange light on dash is on), the highest gear your car will cruise on is 3rd gear.
If OD is on (Orange light off), the highest gear your car will cruise on is 4th gear, which is olso known as the overdrive gear.
Logged
SoL
Low End (2000 rpm)
Reply #6 on:
November 05, 2008, 12:06:06 PM »
Oh, sports mode is different from OD off button? I thought they were different. Sports more for CVT, OD off for 4AT.
Logged
lonhong
Idling (800 rpm)
Reply #7 on:
November 05, 2008, 12:59:49 PM »
err... sports and od different? i tot similar... cos my also cvt
Logged
clarence
Reply #8 on:
November 05, 2008, 01:17:36 PM »
I'm not sure about CVT but there's OD in 4 speed auto versions.
Logged
Ying
Mid Zone (3000 rpm)
Reply #9 on:
November 07, 2008, 10:50:54 AM »
should be different coz CVT dont have 3rd or 4th gear mah. I seldom use the sport mode, very noisy.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Latio
