Author Topic: Change engine mounting  (Read 5851 times)
Offline vex
« on: December 02, 2008, 12:40:51 AM »
Has anyone changed their Latio's engine mounting before ? I feel my 3 yr old Latio when go over hump, feels more wobbly than ever, leading me to suspect the engine mounting are lose. Anyone change before, how much and where you change ? Thanks.
Offline Toalson
Re: Change engine mounting
« Reply #1 on: December 02, 2008, 09:37:08 PM »
Usually when mounting is gone or worn, there will louder engine noise as well as increase in vibration.
Offline royroy
« Reply #2 on: December 03, 2008, 12:17:46 PM »
engine mounting problem will lead to car vibrating more. Put ur car to "P", is ur steering wheel vibrating. Put to "D" and feel any diff? If vibrating can be felt , most prob ur mounting if loose or wear and tear. If not, most prob is ur suspension. If u have change to a aftermarket spring. it will shorten ur suspension life span.
Offline vex
« Reply #3 on: December 08, 2008, 10:35:29 AM »
i see, thanks. so what can i replace the original suspension for Latio ? Mine is coming to 100k km already .  i guess Tan Chong can replace but will charge a premium as usual.
Offline fickle
« Reply #4 on: December 10, 2008, 12:53:50 PM »
are the mountings covered in the NPMP?
Offline royroy
« Reply #5 on: December 11, 2008, 02:25:14 AM »
i dunno abt tan chong. my previous car supsension is under warantty.<100KM or 3 yrs. u can try calling tan chong to ask first b4 going down.
Is not a must to change, u will feel more bumpy most of e time. :)
« Reply #6 on: December 15, 2008, 01:11:10 AM »
Mountings should be covered under normal warranty.
