Author Topic: Pump Tyres Air  (Read 30326 times)
Offline Toalson
Re: Pump Tyres Air
« Reply #20 on: December 11, 2008, 10:35:19 PM »
200km ?   :blink: Very far liao wor.
Paiseh... extra 0... it should be less than 20km.
Offline Toalson
Re: Pump Tyres Air
« Reply #21 on: December 11, 2008, 10:38:19 PM »
hi Toalson
ic. gd info. thanks for sharing. then i dun hv to go to HengTyre liao.
every 2weeks need to chk n topup air meh?
Yes, best is to check every fortnightly. I tried and even when on N2 was told to come back to stamford to top up. Then when I tried normal air, it was the same frequency and best of all the kiosk is so much nearer to stamford. And do note not all of them wait for the tyres to cool before topping up thus the tyres would always be under inflate.
Re: Pump Tyres Air
« Reply #22 on: December 11, 2008, 10:40:46 PM »
actually less than 1.6km
(see manual page 8-30)
Re: Pump Tyres Air
« Reply #23 on: December 12, 2008, 01:11:52 PM »
hi Toalson
that's good . thanks for sharing.
Re: Pump Tyres Air
« Reply #24 on: December 12, 2008, 01:13:58 PM »
hi silver
1.6km? haiz, bad lah. how to...
Offline vortex
Re: Pump Tyres Air
« Reply #25 on: December 12, 2008, 03:44:17 PM »
Ya. 1.6km how to ? Unless the petrol kiosk is next door of your block. Think most of us pump while it is hot tyres. Then how to compensate ?
Eg less than 1.6km - pump 210 and 230
1.6 km - 10 km - pump ???
10 km - 20 km - pump ???
Re: Pump Tyres Air
« Reply #26 on: December 12, 2008, 05:17:55 PM »
hi vortex
iagree w u.
sigh.
may be 15km drive, then when arrive there, wait for 15min before start pumping? ^$^
Re: Pump Tyres Air
« Reply #27 on: December 12, 2008, 07:28:16 PM »
Tyres are considered COLD after the vehicle has been parked for 3 or more hours (see same page of owner's manual)
Usually, you can compensate by about 10 to 15 kPa extra when pumping "HOT" tyres
Do invest in a quality tyre pressure gauge and you can check the tyre pressures COLD before you drive to the kiosk and check the tyres when they are HOT and then you can see how much to compensate
on a side note, good read :
http://www.michelin.co.uk/michelinuk/en/car-4x4-van/tyre-pressures-what-happens/20070319171410.html
and
http://www.michelin.co.uk/michelinuk/en/car-4x4-van/what-tyre-pressures/20070319171409.html
Re: Pump Tyres Air
« Reply #28 on: December 13, 2008, 12:37:34 AM »
Hi guys,
I have no time to go to HengTyre @ Kallang there to pump my Nitrogen air for my new GR80 tyres...
Last night, I pump at ESSO fuel stn @ clementi. Those air are not Nitrogen air right?
The front tyres, i pumped 230. The rear tyres, i pumped 210. Follow the common standard, dare not over pump the air pressure. Any comment?
So, now the air in the 4 new GR80 tyres are mixed liao, how ah? Any knowledge need to share with me for this issue?
Thanks in advance.
Yours iagree.
Hi iagree, noticed that the tyre pressure at 270/250 not really that scarely after all (though abit bumpy). I'm on this tyre pressure now after poisoned by some of the bros here. Will monitor the FC + some skills shared by bro fri13th, liewks, toalson,etc.. :thumbsup:
Re: Pump Tyres Air
« Reply #29 on: December 13, 2008, 06:35:41 PM »
and
Recommended tyre prssure for COLD tyres is 200KPa, so for a warmed up tyre, an extra 20KPa in pressure to compensate means one should pump 220KPa.
But in the name of fuel efficiency, I think many forumers are pumping way above the recommended pressure, up to 280KPa.
Re: Pump Tyres Air
« Reply #30 on: December 14, 2008, 03:18:43 AM »
sticker on B pillar on driver side --> 230 kPa (front) 210 kPa (rear)
Re: Pump Tyres Air
« Reply #31 on: December 14, 2008, 01:23:01 PM »
Speed kills more than tyre pressure, sign board on the road "110km/h", how many people follow leh? you always follow?
Re: Pump Tyres Air
« Reply #32 on: December 14, 2008, 02:00:44 PM »
driver errors, mechanical failure do
speed (per se) don't kill
even those who were at 0 kph parked by the road shoulder died when vehicles plough into them
« Last Edit: December 14, 2008, 02:11:54 PM by Silver »
Re: Pump Tyres Air
« Reply #33 on: December 14, 2008, 02:29:10 PM »
like what you said, another car hit a 0 kph car, chances to survive is better if the car was travelling at 30 km/h than 110km/h right? Sure, speeding can consider as driver errors or should i say failure to control the car over speed limit? you can play with words but fact is fact.  :glare: speed don't kill? god bless ;)
Re: Pump Tyres Air
« Reply #34 on: December 14, 2008, 03:02:18 PM »
failure to control car even at speeds below the speed limit can also result in dire consequences
nice simple slogan to have : speed kills
but the truth of the matter is that it is not as simple as that
