Author Topic: Latio Sport Power Window problem  (Read 12323 times)
Offline Goontat
« on: January 16, 2009, 04:20:37 PM »
Hi All,
Experiencing power window dilema, (driver window):-  after wind up the glass will shut but not fully, seems like the glass slide down a little. Is this normal for latio sport or latio in general after a year plus? Just concern in a long run it will slide even more.  :unsure: Any advise out there...thanks.
Re: Latio Sport Power Window problem
« Reply #1 on: January 16, 2009, 05:23:23 PM »
Hi goontat
drive to tcm and ask them to solve for u.
this type of prob is hard to be solved diy.
Offline kraziesg
« Reply #2 on: January 16, 2009, 08:20:15 PM »
You can go back and complaint that sometimes water leaks in due to that. They might change the power window motor for you.
Hi All,
« Reply #3 on: January 16, 2009, 10:57:24 PM »
mine happend for 3 times liao.  Always happen if u use the window frequently, not more than 6 months.  fixed 2 times but 3rd time cannot fixed due to double layer of soundproof.  You can go to TCM and they will do it for you.  I am used to it now so dun care.
Hi All,
« Reply #4 on: January 16, 2009, 11:15:32 PM »
Hi All,
Hi, after i wind up the window (driver side), and after a while i pull the lever again, i can see the glass move upwards. Does that mean that the glass has actually 'slided' down? Is this what u experience?
Offline Goontat
« Reply #5 on: January 16, 2009, 11:22:44 PM »
after realeasing the lever you can actually see the window slide down a millimitre (try do at night coz there will some reflection against the illuminated gauge meter or radio coole...there you can see it slide)..
« Reply #6 on: January 16, 2009, 11:37:52 PM »
Thanks, i take note of this. All this while i am puzzled how come when i pull the lever periodically, the glass still seems to be able to move up every time, and the force is particularly strong for the 2 front windows.
« Reply #7 on: January 17, 2009, 10:55:41 AM »
hi,
just go back TCM and tell them....i had all 4 motors changed due to this problem.....
« Reply #8 on: January 17, 2009, 11:43:38 PM »
hi,
search again, there was old posting on how to DIY fix this problem. some thing like holding the button for longer time etc...
« Reply #9 on: January 17, 2009, 11:46:20 PM »
« Reply #10 on: January 18, 2009, 12:42:08 AM »
I was out just now, during the evening time. Tested all my 4 windows and to my horror all 4 of them slides down!  :ohmy:
But i think this link gives the solution to the problem that the window cannot auto wind-up. Not for this problem whereby the "window slides down a bit after you have winded it up".
« Last Edit: January 18, 2009, 12:46:35 AM by Midnight »
