Author Topic: Idling rpm  (Read 17193 times)
Offline Toalson
Idling rpm
« on: February 03, 2009, 10:30:58 PM »
HI,
Today observed that idling rpm was flucutating between 600 - 700rpm. Wonder if anyone faced with the same issue and was it resolved.
Hope its not like my old car which have idling problem that kinda forced me to change to this. :unsure:
Offline hammer99
Re: Idling rpm
« Reply #1 on: February 03, 2009, 10:46:05 PM »
I always observed that the idling RPM is closer to 800 at Neutral position for Latio (50km) , When Engine is sufficiently warm
Really not sure than 600 - 700rpm is normal ?
Re: Idling rpm
« Reply #2 on: February 04, 2009, 07:16:06 AM »
hi!
mine is abt there oso. think shld be normal. when shift to N, the rpm will be slightly higher - abt 800.
Re: Idling rpm
« Reply #3 on: February 04, 2009, 08:25:48 AM »
Morning,
Mine the same, hovering around 700rpm, at N also around 800 rpm, so should be quite normal. If idling rpm too high, waste fuel.
Re: Idling rpm
« Reply #4 on: February 04, 2009, 09:43:44 AM »
Morning,
my is around 800 too.....
i think this nbumber is normal ba
Offline RG
Re: Idling rpm
« Reply #5 on: February 04, 2009, 09:48:04 AM »
Mine is around 700-800 if i off the aircon and when i turn it on it will be close to 1000rpm...issit normal?
Offline Toalson
Re: Idling rpm
« Reply #6 on: February 04, 2009, 02:09:51 PM »
Thanks all for sharing. Just very concerned since last ride started with similar syptoms and even lead to more problems.
Re: Idling rpm
« Reply #7 on: February 04, 2009, 10:58:10 PM »
Turn on AC and RPM rose to 1000rpm ? Doesn't sound right.
Offline RG
Re: Idling rpm
« Reply #8 on: February 04, 2009, 11:27:24 PM »
any suspecT due to this??i'm not free to go down to AS this few days..
Re: Idling rpm
« Reply #9 on: February 05, 2009, 09:27:19 AM »
700 is normal.
AS servicing, they will tune to 700 on idle reading
for RG, reason maybe the compressor kicks in so it will slightly increase to 1k ba, after awhile did it drop to normal?
Offline lyh1280
Re: Idling rpm
« Reply #10 on: February 05, 2009, 09:35:58 AM »
Bro, wat problem u encountered b4 when idling at 600 to 700rpm? This shd b normal to us, unless too low where ur engine like wan to die, or too high where petrol consumption wil b high. Mine is ~ 600 rpm also.
Simple...
Offline RG
Re: Idling rpm
« Reply #11 on: February 05, 2009, 08:34:39 PM »
700 is normal.
nope...it just maintain..den i off aircon den its normal ard 700-800rpm
Re: Idling rpm
« Reply #12 on: February 05, 2009, 08:49:01 PM »
Is it when you just start the car? Idling rpm when warming up is quite high.
Offline RG
Re: Idling rpm
« Reply #13 on: February 05, 2009, 09:24:28 PM »
tat 1 i know If the engine's cold Rpm will be around 2k and slowly subside to around 800rpm...but not mine..it only stays around 800 if i did'nt turn on the aircon other wise will be ard 1k
Re: Idling rpm
« Reply #14 on: February 05, 2009, 10:28:40 PM »
You mean you rpm with aircon on is all the time at 1K rpm even after driving long distance, then you should get it checked.
Re: Idling rpm
« Reply #15 on: February 05, 2009, 11:51:33 PM »
RG's car is too powerful liao lor, engine modded till need higher rpm to maintain it or else si ciha... kekeke, got big mushroom & snail inside har....
Re: Idling rpm
« Reply #16 on: February 06, 2009, 01:30:54 AM »
engine temp blue lite on - 1200rpm
engine temp blue lite off - 1000rpm
aft travelling 10 mins - 800
aft travelling 30 mins  - 600rpm
Offline RG
Re: Idling rpm
« Reply #17 on: February 07, 2009, 02:22:50 PM »
Wei...u think my Car Garden issit? got mushroom n snail..haha..Engine Stock..liow..a few Bros in here can clarify... :bleh:
Offline Toalson
Re: Idling rpm
« Reply #18 on: February 08, 2009, 08:57:31 AM »
Thanks for the info
