Author Topic: help on horn required  (Read 11074 times)
Offline alexlkk
« on: February 19, 2009, 01:46:04 PM »
any1 attempt to replace the horn for latio? where is the location of the horn in the car
melvinhgf
Re: help on horn required
« Reply #1 on: February 19, 2009, 03:35:35 PM »
in front, behind the front embelm logo. v cute - two small horns in front but not loud
the installer actually took out the front grill to install mine. BUT i must add that i did it together with my LEDs. so am not sure if it is really necessary to remove the front grill.
« Reply #2 on: February 19, 2009, 04:29:04 PM »
Yes, have to remove the front grill to install the horn.. but easy job lah.. ~ mine abt 10 mins settled
Offline zzyzx
« Reply #3 on: February 19, 2009, 05:51:57 PM »
yah dun even have to do wiring. plug and play for me.
Offline Gone with the wind
« Reply #4 on: February 19, 2009, 11:40:36 PM »
If you want DIY, just follow this thread  http://forum.thelatioclub.org/index.php?topic=708.0
Remember to upgrade your horn fuse to higher Ampere, according to the horn spec.
I bought the Stebel horn from Autobac, was on offer $18.90.  Also bought the fuse there.  DIY myself two weeks ago, quite satisfied with the result.
melvinhgf
« Reply #5 on: February 20, 2009, 12:19:27 AM »
yeah must change the fuse...
after changing my horn, i din change the 10A fuse.. so the first few time when i continue to blast the horn (my fav way of venting anger), the fuse blew up.  :crying: so have been horning intermittently...
now i noe... will go check and change the fuse  :devil2: :devil2: :devil2:
« Reply #6 on: February 20, 2009, 12:36:35 AM »
The original latio horn is 3.5amp per side, so total only 7 amp.
most of the after mkt horn is higher amp (so louder), like the Stebel is 6 amp per side, so total 12 amp.
« Reply #7 on: February 20, 2009, 08:51:44 PM »
Errrrr......pardon my ignorant.....why need to change the horn har??? :confused1: :confused1:
melvinhgf
« Reply #8 on: February 22, 2009, 08:58:25 PM »
sound fierce, behave agressively, etc  :devil2:
but the stock horns are really soft and wimpy... tats y i change to one that is louder
Offline blackhatchbk
« Reply #9 on: February 26, 2009, 01:10:19 AM »
ah fuse at wher, usually got many fuse together.
How to identify is for horn?
melvinhgf
« Reply #10 on: February 26, 2009, 03:04:47 AM »
you can check the manual to find the black box of fuses. on the cover they indicate which fuse is for wat parts. u just follow and remove accordingly.
Offline scoobydoo
  • Have wheels will travel... Latio + Silver Wing
« Reply #11 on: March 19, 2010, 11:50:45 AM »
apart from changing fuse, do we need to install a relay?
some pp say must have (else will burn the wiring) but the shop installer said no need. he say a relay is already there supporting the stock horns, no need extra when doing a 2 for 2 replacement.
confused  :confused1:
Drive Safe + Ride Safer = Better Chances of Recovering Our Blood-n-Sweat CPF $$
ICE: Alpine CDA9886 + Infinity REF475A + FS Moving Air Clarity Mk II & 10" e2 Cube Subs + 2 layers sound dampening
Others: Alutec strut + Ultra Racing anti-roll bar + red spring stiffeners front/rear + UTR Evo 5000 + UTR air filter
« Reply #12 on: March 19, 2010, 01:36:51 PM »
for our latio, confirm no need.
if not wrong, new car already have a relay.
If you getting more powerful horn, confirm you need to replace ur fuse from 10A to 15A
Offline scoobydoo
« Reply #13 on: March 19, 2010, 03:59:43 PM »
thanks, cleared my worries.
i'ld drop by autobacs or sim lim later to buy the fuse... this type?
« Reply #14 on: March 19, 2010, 05:43:08 PM »
tio lah, this mini type, not the bigger one.
