Author Topic: depress brake all the way  (Read 15491 times)
« on: March 14, 2009, 11:47:05 PM »
normally when parking, do u depress the leg brake all the way down or juz halfway?
Re: depress brake all the way
« Reply #1 on: March 15, 2009, 12:06:56 AM »
all the way down.
« Reply #2 on: March 15, 2009, 12:23:08 AM »
same as you would "pull" up the handbrake all the way ........
Offline latioboy91
« Reply #3 on: March 15, 2009, 12:31:31 AM »
wah all the way down means later when u depress again to bring it up, its very hard. haha. usually jus push it and hear about 3 clicks haha!
« Reply #4 on: March 15, 2009, 08:25:08 AM »
I think same as hand brake....if you consistently push it all the way down....the foot brake will become loose over time just like hand brake and u realised u need to push it all the way down more.....but when servicing...they should adjust it for you and it will be fine.....i used to pull the hand brake of my previous all the way up....and then over time...i find tat it is not tat good.........
« Reply #5 on: March 15, 2009, 09:40:15 AM »
that is due to the wearing down of the brake pads
« Reply #6 on: March 15, 2009, 10:02:35 AM »
I think we're talking about the parking brake. It won't wear out unless you drive off with it~!  ;D
« Reply #7 on: March 15, 2009, 10:07:36 AM »
i meant that the parking brake activates the brake pads to "hold" the car in a parking position
so as the brake pads wear out under normal braking, the travel distance required to fully engage the parking mechanism is increased due to the bigger clearance of the pads to the disc/drum
« Reply #8 on: March 15, 2009, 11:28:37 AM »
Err, isn't the parking brake a seperate brake pad? On most cars its a smaller pad, activated by wire tension instead of fluids. Not too sure on Latio, you may be right!
« Reply #9 on: March 15, 2009, 02:12:38 PM »
Parking brakes are normally on the rear wheel. It should be usingthe same brake pads as the normal brakes.
« Reply #10 on: March 15, 2009, 03:28:09 PM »
On level ground, just one click will do, if slope, 2 clicks. SO far, 2 clicks are sufficient for me before i put the gear to 'P'.
« Reply #11 on: March 15, 2009, 03:38:10 PM »
2 clicks if okay until you start throwing in suitcases and stuff and the car rolls down the slope with the weight. Heheh never happened before, just saying, but why not push down more? I use around 4 clicks on slopes. Better to be safe then sorry!  :bleh:
Offline AhXiong
« Reply #12 on: March 15, 2009, 05:46:00 PM »
On level ground, 1-2 clicks for me.
If slope, then I step all the way down loh
How come everybody post count all so high?
Chiong arrgghhhh. +1  :uppercut:
Offline Toalson
« Reply #13 on: March 15, 2009, 09:17:13 PM »
I recently did that  :ohmy: and was wtf when the car keep sounding the warning alarm, tot was tat i drop my ikey. Silly me.  :hammer:
« Reply #14 on: March 16, 2009, 01:55:13 PM »
u mean when parkin foot brake not release ther would be warnin sound to alert the driver?
« Reply #15 on: March 16, 2009, 08:11:22 PM »
I would think it works like the handbrake. u pull it too hard often, it will become loose. Then u will find that it does not hold anymore when u really need it on a real steep slope! So usually i just depress about enough. It really steep slope, i think maybe 3 clicks.  :smile:
« Reply #16 on: March 16, 2009, 09:48:11 PM »
I happened to have the Nissan service manual for Versa(US version of Latio), and their handbrake is wire activated. So I would imagine its the wire becoming loose after a long time. Should be able to ask the mechanic to tighten for you when servicing.
« Reply #17 on: March 17, 2009, 11:23:38 PM »
ya lor..never heard of alarm when I drove with brake on lei?
Offline Toalson
« Reply #18 on: March 18, 2009, 12:23:41 AM »
Well mine did when I forgot abt the foot brake and started driving. Or maybe its for FL only. :confused1:
