Author Topic: Which Brake Pad to use???  (Read 21455 times)
Offline SpeedLimit
« on: April 13, 2009, 12:23:43 AM »
Hi newbies here,
how does the temp specification in the brake pad help in braking??
If driving at 100 - 140kph? which 1 to use?
Offline RG
Re: Which Brake Pad to use???
« Reply #1 on: April 13, 2009, 08:06:53 AM »
The temp spec. affects its endurance...higher the temp u can brake at high speed frequently..usually 400"C is enough for our Latio
Can try Bendix and Fuji..
Offline SpeedLimit
« Reply #2 on: April 13, 2009, 10:46:15 AM »
Thanks bro
« Reply #3 on: April 13, 2009, 10:50:11 AM »
used bendix b4, initial grip was superb! but then after 2 hard jam brakings, the grip like not as good. not too sure is it because the pads were burnt?
« Reply #4 on: April 13, 2009, 03:26:51 PM »
Some performance brake pads create a lot of brake dust which will 'dirty' your rim. if dun mind then ok.  :smile:
« Reply #5 on: April 13, 2009, 05:02:04 PM »
confirmz...my current B brake pads are like dust producing machines...1 day of driving, and the whole rim is like MATT finish
Offline pest11
« Reply #6 on: April 13, 2009, 08:33:55 PM »
still on stock-brake after 63K with ~20% left ...... for safety sake, had it replaced last wk with original stock-brake .....  :thumbsup: enuf for me !!
« Reply #7 on: April 13, 2009, 10:34:02 PM »
I guess if u r not a chiongster, stock brakepad will suffice. I like matt look, but not on my rim  ;D
Offline SpeedLimit
« Reply #8 on: April 14, 2009, 11:41:26 PM »
think original brake will be enough for me
i don't like matt look   :D
Offline RG
« Reply #9 on: April 15, 2009, 12:38:25 PM »
Hmm..never Experiance it b4..it survive my Thrashing Up n Down Genting definately more than 2 hard jam brakes and even at OG :devil2:, wad kinda rotor ur using?
« Reply #10 on: April 15, 2009, 08:28:50 PM »
yah....i also dunno why....was seriously damn good b4 the 2 hard jams....anyway, im using cross drilled slotted ones, but same size as stock.
Offline RG
« Reply #11 on: April 16, 2009, 01:09:05 AM »
i've tried stock rotor...was better than normal brake pads den after changed to cross drilled slotted, it became better... I've juz changed to a brand called Fuji, my mechanic says its the same as bendix metal king except that it can last much more longer..
Offline ac1d6urn
  • Shift The Future
    • Chee Kwong Guan
« Reply #12 on: April 16, 2009, 08:36:42 AM »
What is the model code for Fuji Brake Pads?
Think Safety . Feel Safety . Drive Safety
Offline RG
« Reply #13 on: April 16, 2009, 03:40:13 PM »
Can't remember i'll call up my mechanic to check den i'll post here ya..
« Reply #14 on: April 17, 2009, 01:33:57 AM »
how many moolahs?
Offline RG
« Reply #15 on: April 17, 2009, 09:53:45 AM »
Wads Moolah?? :out:   Price issit??  it cost me $110
« Reply #16 on: April 17, 2009, 08:24:25 PM »
okok thanks!
« Reply #17 on: April 20, 2009, 08:57:26 PM »
Using Asuki japanese brake pads now. Damage $70 with install. My high temp ones gone!! after less than 3 months!! And i bloody paid $150 for those. Was good initially also, super dust producer, got sqeaky sounds, and best of all, gone in under 3 months....
Offline SpeedLimit
« Reply #18 on: April 21, 2009, 12:20:12 AM »
bro, wat u mean by cross drilled slotted?
btw, i have change my brake pad and how do we know when the brake pad wear off?
accident?  :D joking...
« Reply #19 on: April 21, 2009, 08:32:56 AM »
Change both front and rear brake pad at AS last week.
Now there is a tick tick sound from the drum brake during braking, went back to AS and they say this is normal as new brake pad is uneven and sound would go away once the wear and tear set it.
True? :confused1:
