Author Topic: tyre pressure  (Read 40334 times)
Offline kenmaine1008
tyre pressure
« on: April 20, 2009, 01:16:16 PM »
hi all... newbie here...
just want to ask if i pump 230 for both front and rear is it acceptable??
under the tire placard... it states 230 for front.. and 210 for back...
Le Kua Simi? (x 2)
see my super chio rim~
Le Kua Simi?
my car more swee~
Re: tyre pressure
« Reply #1 on: April 20, 2009, 02:48:09 PM »
When I in stock, previously I pumped 250 front and 230 back.
Re: tyre pressure
« Reply #2 on: April 20, 2009, 02:54:19 PM »
same pressure I pump. Find it the most optimal for stock tyres for fuel Economy
Re: tyre pressure
« Reply #3 on: April 20, 2009, 03:58:34 PM »
wah.. so high ah... means the front must be always higher than the rear?
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
syler
Re: tyre pressure
« Reply #4 on: April 20, 2009, 04:06:36 PM »
Front higher because got engine load + Driver, thus more pressurce on the both front tires.
Re: tyre pressure
« Reply #5 on: April 20, 2009, 04:32:57 PM »
The pressure quoted is when the tyres are cold. To cater for factors of expansion and contraction, we should pump slightly more. Mine is 250 front and 230 back.
Re: tyre pressure
« Reply #6 on: April 20, 2009, 05:40:38 PM »
wah..okie... the other time when i collected the car.. the se pump 220 only for all...
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
Re: tyre pressure
« Reply #7 on: April 20, 2009, 05:44:27 PM »
hmm.. also any idea wat is the max we can pump for front and rear??
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
Re: tyre pressure
« Reply #8 on: April 20, 2009, 06:33:13 PM »
Yea.  :thumbsup:
Re: tyre pressure
« Reply #9 on: April 20, 2009, 10:23:24 PM »
You will know when you pump until your tyre burst lor....haha.... :devil2: :devil2: :devil2:
Re: tyre pressure
« Reply #10 on: April 20, 2009, 10:33:51 PM »
The front tire i ever pump until 280 and back tire 260, when the tire is hot. Sounds a bit scary yah?
And i achieve 15km/litre
Then i drop to 265 for front and 245 for back, pump when tire is hot, also 15km/litre.
I think i will stick with these pressure. My tires and rims are stock.
Re: tyre pressure
« Reply #11 on: April 21, 2009, 12:21:48 AM »
wah.. u are so hardcore my fren...
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
Re: tyre pressure
« Reply #12 on: April 21, 2009, 01:21:11 AM »
different station pump different calibration. So if u go to Caltex station pump 230, then drive to Esso, then u try u be shock the reading is 250. Then U drive to shell wah the reading is 210.
So stick to your regular pump.
SPC pump the most lao ya. Esso and Caltex quite ok, but caltex must see location.
Re: tyre pressure
« Reply #13 on: April 21, 2009, 07:56:23 AM »
If you pumped when your tyre is hot, should be o.k, but if your tyre is cold and you pumped 280, then is scary.  :bleh:
Re: tyre pressure
« Reply #14 on: April 21, 2009, 08:25:42 AM »
when cold.. i pump 270 front and 280..
feel quite good....
Offline rongshu
Re: tyre pressure
« Reply #15 on: April 21, 2009, 09:15:28 AM »
don't you guys feel the ride is bumpy if tire pressure at 270? i once tried 240 front and 220 back, my wife complians too bumpy for her to read the pda screen.  she will feel headache after a while reading the pda screen.
« Last Edit: April 21, 2009, 09:17:37 AM by rongshu »
Re: tyre pressure
« Reply #16 on: April 21, 2009, 03:24:25 PM »
feel quite good....
Bro,
You pumped 280 when cold, it may reach more than 300kpa when hot. Becareful, take it as a sound advise. You can see why some encountered burst tyres on NSHW.   :zipped:
Offline vortex
Re: tyre pressure
« Reply #17 on: April 21, 2009, 04:15:26 PM »
The max pressure is indicated on the tyre. Think for our stock, it is 250 kpa. Be careful for bros pumping much higher than this.
Re: tyre pressure
« Reply #18 on: April 21, 2009, 05:47:50 PM »
I kenna one time before when i pumped at one of the stations. Can't seem to hear the buzzer that indicated the intended pressureg has been reached. Go to next door station, discovered that instead of pumping more air, the previous pump drew air from the tyres. The pressure has fallen to below 150 KPa.
Re: tyre pressure
« Reply #19 on: April 21, 2009, 07:45:13 PM »
Bro,
eh.. sorry.. wat do u guys meant by hot and cold?
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
