Author Topic: Battery Water  (Read 8666 times)
Offline erictay_82
Battery Water
« on: May 03, 2009, 10:30:40 AM »
I would like to find out how we can check the battery water level? what is the recommend level?
Re: Battery Water
« Reply #1 on: May 03, 2009, 10:39:01 AM »
There is a 'max' or 'upper limit' marking on the battery? Follow that, sometimes a b it difficult to see the level from outside, so just estimate.
Offline erictay_82
Re: Battery Water
« Reply #2 on: May 03, 2009, 10:49:42 AM »
what is the recommend level? I went for servcing, TCM mentioned to check battery water level
Re: Battery Water
« Reply #3 on: May 03, 2009, 11:15:45 AM »
if difficult to see the level from outside, you can check the level by opening and looking into each cell
add demineralized/distilled water up to the UPPER LEVEL line
you will get more information on page 8-21 of owner's manual .........
Re: Battery Water
« Reply #4 on: May 03, 2009, 11:42:01 AM »
It is their standard advise given.
I changed the battery from TCM less than a month a go and after servicing i got the same advice on the report.
Re: Battery Water
« Reply #5 on: May 03, 2009, 11:45:00 AM »
That is their default template, never change one, some items they never check also tick checked & passed
Re: Battery Water
« Reply #6 on: May 03, 2009, 02:04:47 PM »
Well....at least if things go wrong, they can't deny not having checking it.....some sort of guarantee i suppose...
Offline SpeedLimit
Re: Battery Water
« Reply #7 on: May 03, 2009, 04:17:17 PM »
even maintenence free battery, tcm also will indicate check...
Re: Battery Water
« Reply #8 on: May 03, 2009, 04:49:02 PM »
Even for MF battery, still have to check (check the color to see if it is time to change battery).
Offline erictay_82
Re: Battery Water
« Reply #9 on: May 03, 2009, 05:53:10 PM »
I tried to open and check. but v difficult to see.....i just roughly pull some battery water in.
Re: Battery Water
« Reply #10 on: May 03, 2009, 06:00:06 PM »
hope you did not overfill
best to check in daylight or use a torchlight
Offline kennytoh
Re: Battery Water
« Reply #11 on: May 04, 2009, 11:33:32 PM »
how frequent shd we check for the battery water for topup??
Offline nymin9
Re: Battery Water
« Reply #12 on: May 04, 2009, 11:37:14 PM »
i never top up in 2 yrs plus. only @ serving at tc they do it. so far so good. changed my batt a few months ago just cos i tot time to change though my sa told me still ok.
To Lead is to Serve!!!!
