Author Topic: 40K servicing  (Read 23333 times)
Offline starushz
40K servicing
« on: May 19, 2009, 12:10:42 AM »
Hi guys,
I was thinking to do my 40K servicing at autosavers.
What actually needs to be done at 40K?
Heard from TCM need to change the belt blah blah....
if change at autosavers do I need to tell them to change or will they automatic follow TCM method and change all that is neccesary?
Re: 40K servicing
« Reply #1 on: May 19, 2009, 10:05:01 AM »
Hi guys,
I did my at Autosavers Ubi, they will service according to the Nissan list but will call you to inform if its ok to proceed to change.
I had long given up servicing at TCM. Not sure if the rest of the bros encountered this,
- Send in car to check on Steering coupling. Aircon set at 26C
- Car return with aircon set at 18C and additional 4K on the mileage
- Tell them not to wash engine bay, but return with engine bay wet,wet
- Tell them not to wash car but return with car wash and wet driver side mat
- Tell them not to replace wiper (new ones), they replaced and throw away.
Offline header
Re: 40K servicing
« Reply #2 on: May 19, 2009, 03:40:35 PM »
What is the estimated charges for 40K servicing?  After change this & that?
I find autosaver items (eg.  battery, tires, air filter, etc.) more exp than outside...
Re: 40K servicing
« Reply #3 on: May 19, 2009, 04:02:54 PM »
Wah... 4KM or 4000KM on the mileage? which branch u went?
Re: 40K servicing
« Reply #4 on: May 19, 2009, 05:18:44 PM »
Re: 40K servicing
« Reply #5 on: May 19, 2009, 05:21:39 PM »
Go to www.autosaver.com.sg to check it out.
Get battery, tyres, air filters outside, esp the aircon filter, which they will charge $60, outside.
You will get more bang per $
Offline starushz
Re: 40K servicing
« Reply #6 on: May 19, 2009, 10:45:21 PM »
What about the belt? need to replace?? brake pads/fluid?
possible to provide a list of stuff to get before goign to autosavers??
so that i can go purchase them
Re: 40K servicing
« Reply #7 on: May 19, 2009, 11:57:42 PM »
Brake pads these kinda stuff better to let them replace, they use OEM pads. Unless you want performance ones of course. I kena tok by them before also, air filter, AC filter, wiper. All overpriced.
Bro please update after you do your servicing, I'm going soon as well.  :D
Re: 40K servicing
« Reply #8 on: May 20, 2009, 08:27:15 AM »
For me, I am getting,
a) Engine air filter, approx at $15
b) Enginer oil filter, at $5.5
c) Aircon filter, at $18 (not necessarily for every servicing)
d) Wiper Blade (Bosch) $15 per pair
e) Enginer oil
All filters can be bought at Bendemeer road, two shops away from H-tyres. Was recommended by Bro IAGREE.
Yes, for brake pad, I did get them replace at Autosavers but cost on the high side, $135 for disc and $125 for drum.
Hope these helps
Offline totallypatrick
Re: 40K servicing
« Reply #9 on: May 20, 2009, 08:46:49 AM »
Besides autosavers and TCM, anybody tried other places for servicing?
Re: 40K servicing
« Reply #10 on: May 20, 2009, 08:50:18 AM »
I'm at Lok Yang now to get my brake assembly checked...  check out the new price list from TCM..
http://www.nissan.com.sg/service/pkd_psg.pdf
wah lau... autosaver any day man..
Re: 40K servicing
« Reply #11 on: May 20, 2009, 08:53:30 AM »
e) Enginer oil
Hope these helps
You bring all these to Autosaver  to install?? So oni pay labour charge eh?
Offline header
Re: 40K servicing
« Reply #12 on: May 20, 2009, 09:00:25 AM »
e) Enginer oil
Hope these helps
Thks for sharing the list!  Engine oil filter & wiper blade I thot is included FOC? Autosaver wiper balde losy though, cant last 20K.
What is the name of shop?  Is it 2 shops before H-tyres?  Becos if I remember correctly H-tyres is already near the end of the row of shops.
Re: 40K servicing
« Reply #13 on: May 20, 2009, 11:45:10 AM »
Sorry, I meant 4km. Did it at Ubi
Think the additional 4km is reasonable as mine also about the same when requested for steering coupling change, they need to test drive to ensure it working condition and nothing loose.
Re: 40K servicing
« Reply #14 on: May 20, 2009, 05:20:03 PM »
Sorry can't remember but address is 50 Bendemeer Road.The brand of the EO filter is Mirco.
EO filter rebate $10.50, wiper blade rebate at $22 from Autosavers. If you join the AS membership, you will get another 15% dis on the servicing.
Re: 40K servicing
« Reply #15 on: May 20, 2009, 05:24:04 PM »
Noted with thanks.
I had went to Ubi TCM for checks on the SC but in the end, they never change as the SA told me they just tighten the assembly only. Replacement would cost $400++
Not satisfied with the answers, I called up TCM@ LokYang and the SA told me, there is no need to change the SC as there is no safety issues with it :confused1:
Can any bros advice if this is true?
Thanks!
Offline carowner
Re: 40K servicing
« Reply #16 on: May 20, 2009, 09:50:25 PM »
Read the TCM servicing schdule and it indicates that they changed the drain plug wasger. Does Autosaver changed the drain plug washer?
Re: 40K servicing
« Reply #17 on: May 20, 2009, 10:15:21 PM »
Noted with thanks.
Thanks!
This steering coupling thing to me is a design flaw to me, more prone to spoil compared to other cars? Advised by the SA at TCM is that there is no safety issue with it but u have to bear with the 'tok-tok' sound when doing U turn or parking, full-locking the steering.
Was advised by others that the steering coupling defective because we often turn the steering when car is not moving (i dun understand the rationale behind it though). I will bang table at TCM telling them that this is obviously design problem. So many ppl get it changed in such short period of time! Try to change it for free.
Re: 40K servicing
« Reply #18 on: May 22, 2009, 08:23:04 AM »
Mine is coming 4 year old soon, so no warranty. :(
Since, there is no safety issue, I will just bear with the tok -tok sound
Offline starushz
Re: 40K servicing
« Reply #19 on: May 22, 2009, 08:30:20 AM »
I still have another 7K more..but better to get some info first...
