Author Topic: Brake pads. When should I start changing it?  (Read 45136 times)
Offline totallypatrick
Re: Brake pads. When should I start changing it?
« Reply #40 on: June 15, 2009, 10:21:15 AM »
I got them from Aoto
After changin to HEL hoses, can feel that the brake pedal does not have the spongy feels anymore esp when brakin hard at fast speed. As this is a budget & cost-effective way of improvin the brake system, but if i hv the extra dough i would change the rotors and callipers too. . . :P
But if you wanted to change rotors and callipers I think its more worth to buy a complete set cause change 1 by 1 is not really cost effective? By the way, for the brake fluid, whats dot5.1 and dot4 do you know? whats the diff? Also does the shop change all of the brake fluid or top up only? Also is this SS brake hose meant for latio model or customize to fit? Sorry for being so loh soh...  :unsure:
« Reply #41 on: June 15, 2009, 11:03:36 AM »
ok bcoz at the moment i dun hv spare cash to change the entire brake system dat would cost 1k+ and bcoz if i were to change as a complete set, they would not have HEL hoses to go with their package, as i aimin at VTTR
For brake fluids wat i know is diff specs is meant for diff car usuage eg. street drivin, race use or extreme driving.
As for brake fluid change, they will drain out ur old fliuds & do a complete fluid change & bleedin for u...
SS hose i got no idea, I'm usin HEL brand & its custom to fit, another gd brand i recomend is Goodridge.
No prob dats wat forum is for... to share & to find out yeah :)
« Reply #42 on: June 15, 2009, 12:20:52 PM »
thanx for the info bro. I'm also interested in HEL brand as I saw it in hotstuff mag. Din noe it cost more than $300. heehee.. pretty ex..
« Reply #43 on: June 15, 2009, 06:51:39 PM »
Ya correct i've been usin HEL for most of the vehicles i used to owned even for my motorbikes... Its worth the money well spent as u can feel the difference & result will prove to u dat those ah chee pah lia hoses dat cost over $200++ is not dat great & cheap after all. . .
Offline tayyw76
« Reply #44 on: June 15, 2009, 11:34:59 PM »
I'm using the bit spot hose for my ride.. they can use back the original connectors so dun need those able tie to tie here and there..
« Reply #45 on: June 16, 2009, 03:23:42 PM »
Do they (AOTO) have direct bot on brake disc (Rotor) for replacement?? how is the max size can a stock caliper can hold?
Interested in upsize my Rotor... no sure where to get it done....
« Last Edit: June 16, 2009, 03:28:27 PM by NSman »
« Reply #46 on: June 16, 2009, 04:10:25 PM »
Upsize got leh..Racetech selling abt $700 like tat plus fabricate a bracket for u. How BIG u wanna go oso can..heehee
« Reply #47 on: June 16, 2009, 04:43:22 PM »
don wan too big lah, 280mm or 302mm good enough... Racetech one so ex....
Offline kanzo
« Reply #48 on: June 16, 2009, 04:45:38 PM »
so expensive.. wonder if the rotor for jazz can fit our ride only $400 include brackets
« Reply #49 on: June 16, 2009, 05:16:23 PM »
Upsize is around that price bro..between 600 to 700 unless take OE size then 200 plus have liao.
Offline kanzo
« Reply #50 on: June 16, 2009, 05:29:15 PM »
no wor..$400 is upsize slotted rotor liaoz.. u go check.. runstop rotor.. FJC always have GB
« Reply #51 on: June 16, 2009, 05:44:04 PM »
Oh I saw RunStop leh. But it says specially for jazz?
Offline vypez
    • need help with words?
« Reply #52 on: June 16, 2009, 05:45:27 PM »
eh bro,
might as well you buy a subaru 4p front and modify in. a 4p will cost you ~ $500, modify and wack in, also almost same cost as you change rotors and calipers... and its 4P!
Offline kel81
« Reply #53 on: June 28, 2009, 10:38:15 PM »
hmm i was thinking bout this too.. but upsize rotor, calipers nv change got effect?.. our rotor looks tiny on 17" rubber.
nothing left...
