Author Topic: left head light not working  (Read 5796 times)
Offline wanaka
« on: May 25, 2009, 10:36:48 PM »
My left side head light won't on.  Just wondering for this kind of problem are you guy going back to Tan Chong.  That day I accidentally knock the front bumper to the car park wall and now got a scratch.  Not sure whether that cause the head light not working though there is no crack on the head light.  By the way which shop normally you guy go to repair those scratch and paint work as I think TC will be very expensive.
Offline hammer99
Re: left head light not working
« Reply #1 on: May 25, 2009, 10:46:43 PM »
If you can bear with the scratches, then no need repair them immediately, becos minimum charges will be 3 digit figure leh, no workshop will do anything less than that amount nowaday. Alternatively, can buy touch up paint from DIY shop, if the scratch is not that serious.
If you still have servicing with TCM, then wait for next servicing to have the light change, else can look under commercial posting for lobang.
« Reply #2 on: May 26, 2009, 05:37:03 PM »
then have to make up story if tp stop your car at night coz your headlight not in working condition. Next servicing can be months apart leh.
Offline kyorei82
« Reply #3 on: May 26, 2009, 06:32:15 PM »
bro, u can try polishing it..if the scratch is not too deep...or else...u can get it fix for 80-120..if u gt time to look ard for work shop...but could it be ur bulb blow?
30% on ride, 70% on driver....
-=License to SPEED=-
-Front 2 pot brakes, rear single pot
-Customise Coilover
-Full UR brace
« Reply #4 on: May 26, 2009, 10:40:31 PM »
Does yr headlight problem appears immediately or on the same time which u bang yr bumper? Maybe the connector inside came loose. If you know how to, locate it and put it back....
