Author Topic: steering wheel lock and unlock  (Read 9939 times)
Offline foofam77
« on: November 27, 2009, 07:27:01 PM »
with latio's keyless ignition, are we still able to "steering wheel lock" it?
how to do it?
and of course, how to unlock it?
i know different car brands have different ways.
thanks
Re: steering wheel lock and unlock
« Reply #1 on: November 27, 2009, 08:26:21 PM »
check out page 5-7 of owner's manual
Offline foofam77
« Reply #2 on: November 28, 2009, 11:40:36 AM »
i lost mine...care to share how i can download the car manual, or better still, let me have the information over this forum?
thank you
later, i will try googling too to see if i can find anything
« Reply #3 on: November 28, 2009, 11:52:31 AM »
To lock steering wheel
1. Turn the ignition switch to the "LOCK" position.
2. Remove the key, if it is inserted in the ignition switch.
3. Turn the steering wheel 1/6 of a turn clockwise from the straight up position.
To unlock steering wheel
1. Insert the key into the ignition switch, if necessary.
2. Gently turn the ignition switch while rotating the steering wheel slightly right and left.
Offline foofam77
« Reply #4 on: November 29, 2009, 09:30:16 PM »
hey thanks silver...
whenever i switch off my engine, i have always turn it to "ON" position.
So if i want to switch to "LOCK" position, does that mean from "ON" position, i push the ignition switch and turn inwards towards "LOCK"?
OR from "START" position, i can straight away push the lever and turn towards "LOCK"?
« Reply #5 on: November 30, 2009, 08:57:43 PM »
you are most welcome - just stating what's in the manual
both options are possible
the (gear) selector lever has to be turned to the "P" (Park) position before you can turn the ignition switch to the LOCK
