Author Topic: Mixed EO?  (Read 2939 times)
Offline tchekchuan
Mixed EO?
« on: December 08, 2009, 12:02:33 PM »
ANyone uses mixed EO when you do car servcing? For example, 3 Quartz of Amsoil mixed with 3 Quartz of Redline etc...  :yehyeh:
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
Re: Mixed EO?
« Reply #1 on: December 08, 2009, 06:38:43 PM »
erm bro ....if the vicosity is the same its alrite........same rating is ok but dun mix smetink like 4 w50 mix wif smetink else lah
n if engine oil mix will some other kind of lube also can....example nano lube or x1r...
LaChio
Re: Mixed EO?
« Reply #2 on: December 11, 2009, 04:10:55 PM »
Full synthetic EOs can be mixed. I ever did with 2+ ltrs of Mobil1 Gold 0W40 with 1 ltr of Castrol SLX 0W30. Car ok, nothing wrong leh.
But you cannot mix full synthetic EO with mineral EO.
Offline Huatster888
Re: Mixed EO?
« Reply #3 on: December 11, 2009, 08:53:58 PM »
u mix diff grades???nt reali tat recommended
Re: Mixed EO?
« Reply #4 on: December 11, 2009, 11:25:03 PM »
For me i am not technically competent in EO and stuffs, so i will always use the same brand of EO.
But i think different viscosity is ok because it only affects how thick your EO will be.
Mobil 5w30 (less thick) + Mobil 5w40 (thicker) = still Mobil, just that after mixing, the EO thickness will be btw w30 and w40?
Having said that, i will still try my best to use the same brand and same thickness la...
Offline loony
Re: Mixed EO?
« Reply #5 on: December 22, 2009, 03:06:26 PM »
I ever mixed 1 quartz of Amsoil with 3 quartz of redline. All are 5w30.
No strange behavior encounter, did that cause the 1 quartz of Amsoil already opened and feel a bit waste if I just throw away.
Check with the technician, he said no problem. Then I just tell him to go ahead and mix them.
