Author Topic: Significant power loss when air con on  (Read 5263 times)
« on: May 10, 2010, 09:32:46 PM »
Need some advice from bro/sis
discover recently sever power loss when air con is on this resulted super high fc and sluggish pick up
checked tyre pressure and car just 5k from last servicing
when i off the air con the ride and power feels normal as before
is this a sign aircon failing?
Re: Significant power loss when air con on
« Reply #1 on: May 13, 2010, 10:29:10 AM »
It is normal for cars of the Latio's capacity (1500cc) to feel a loss of power, particularly when accelerating when the air con compressor kicks in.
But if you were to drive a larger capacity car like the 2000cc Nissan Teana, you woudl not feel such an effect as the engine has sufficient power.
« Reply #2 on: May 13, 2010, 12:17:15 PM »
I feel the same thing too.. but i'm not sure what you mean by extreme lah.. I suspect the bearing in the a/c compressors are rusting.. that's why when the electromech clutch cuts in u feel the load on the engine.
Btw, i asked TCM if we can grease the bearings but they claim it's sealed...
Offline m_k_tang
« Reply #3 on: May 14, 2010, 01:03:35 AM »
Perhaps, you can try out UTR Power Charger Evo Series for your power loss from your electrical loads. If you are not satisfied with UTR Power Charger Evo Series within 7 days, you can return it for a refund.  :smile:
More information of UTR Power Charger Evo Series at: http://forum.thelatioclub.org/index.php?topic=9894.0
