Author Topic: Power outlet. SOS!  (Read 8851 times)
Offline serenez
  • Car Color: black
Power outlet. SOS!
« on: October 29, 2010, 01:10:01 PM »
Afternoon all...
I bought a portable vacuum cleaner yesterday and after insertin to the power outlet, there's a little spark. Did I blow the fuse? How much is it to repair it?
Re: Power outlet. SOS!
« Reply #1 on: October 29, 2010, 02:09:47 PM »
do you still get power from the power point? try with other device eg GPS charger..
If no power then can check for the fuse in engine bay. Should be a spare fuse there.
Offline boey
« Reply #2 on: October 15, 2012, 10:36:34 AM »
Anyone face problem on the power outlet? I can charge as the outlet got no power coming in. Who can i look for?
Offline vinzlee
  • Look ahead of situation
  • Car Color: Silver
« Reply #3 on: October 15, 2012, 11:09:41 AM »
Have a look at the power socket to check whether any 'metal' object trapped within that possibly caused a short-circuit, that may blow out your fuse if so.
Offline boey
« Reply #4 on: October 15, 2012, 11:33:31 AM »
I have checked nothing trapped in everything is ok just that no power for charging GPS. Dun know how much the cost for repair.  :confused1:
« Reply #5 on: October 15, 2012, 12:35:02 PM »
think u blow the fuse liao.. Go to workshop to change... very cheap one..
btw> u also check ur vacuum cleaner.. see got any metal or water stuck to the plug
Offline boey
« Reply #6 on: October 15, 2012, 02:27:02 PM »
Maybe you r rite. Thanks for the advice.  ::)
Offline spyder_696
« Reply #7 on: October 24, 2012, 04:12:47 PM »
Afternoon all...
fuse blow just change yourself...
buy from most malaysia supermarket...
u can read where is the ciggy plug fuse on the pull out panel itself...
if you go to your frequent workshop to change... most likely it will be free...
this is really very cheap stuff...
Offline edwardtkh
« Reply #8 on: October 24, 2012, 10:54:58 PM »
I faced the same problem too, blew the fuse. Just replaced it yourself, it is very easy, plug and play type. Should be a red fuze (mini blade fuze) 15A.
Cost wise its ard 2bucks. Can get it at sim lim tower those elect shops.
