Author Topic: Switching to Neutral Gear at stationary saves Fuel? (4AT/CVT)  (Read 32913 times)
Offline rodrigue
hey pple, i heard n read abt the above mentioned. is tat true?
thks  :smile:
Re: Switching to Neutral Gear at stationary saves Fuel? (4AT/CVT)
« Reply #1 on: May 11, 2008, 10:49:16 PM »
Bro, if you're not at a traffic junction waiting for the lights to turn green, your engine should be off so it doesn't really matter if it's at neutral or not, just that you won't be able to start your ride later if your gear is engaged. If you're at the traffic junction, how long is the wait? How much can you save?
Offline idiotboi89
« Reply #2 on: May 11, 2008, 10:54:31 PM »
dont know about netural but parking the rpm idles at 800, i put D step brake idles at 600 or so.  :D
« Reply #3 on: May 11, 2008, 11:47:00 PM »
Theoritically is the same, idle mode, free wheel therefore is 800rpm, but when engage to D, driver is rotationg with a force coz driven is stopped by our power brakes.  :smile:
« Reply #4 on: May 12, 2008, 08:41:16 PM »
thks  :smile:
Answer is in last week's free issue of the CarBuyerGuide.
Offline idiotboi89
« Reply #5 on: May 12, 2008, 09:04:17 PM »
weird i thought stepping brakes they disengage or something, if not sure damage something right?
Offline ckyc
« Reply #6 on: May 12, 2008, 10:17:14 PM »
I also tot of this.. perhaps can save a penny, but later gear box spoil ... then not worth liao
Offline rodrigue
« Reply #7 on: May 12, 2008, 10:38:35 PM »
oh okies... thks alot for ur views..  :smile:
Offline hope_n_pray
« Reply #8 on: May 12, 2008, 10:40:35 PM »
I didn't manage to get my hands on it. So what's the answer?
« Reply #9 on: May 12, 2008, 10:54:06 PM »
Obviously you do not know how an automatic gear works.  :D
MT is using clutch and gear, when you step the clutch, it disengage, but driver still turning.
AT is by fluids, that is why when you let go brakes, it moves. Nothing is being damage. Go read up more and you will understand.  :thumbsup:
« Last Edit: May 12, 2008, 10:56:35 PM by Jazz »
« Reply #10 on: May 12, 2008, 10:57:30 PM »
This is called penny wise, pound foolish.  :D
« Reply #11 on: May 12, 2008, 11:08:11 PM »
Based on my understanding of Question 76 which says something about coasting in neutral vs in gear.  The logic is the same for stop vs coasting.  The real question is whether fuel supply will be cut off in order to save fuel.
The text is ".......Modern fuel injection engines cut off the fuel supply to the cylinders when you lift your foot off the accelerator pedal, BUT ONLY IF THE CAR IS IN GEAR."
(Please note words in CAP.  Hence, if the car is not in gear, the fuel supply will not be cut off.  Think quite a number of ppl (myself included) think that engaging neutral and let the car roll slowly towards the traffic red light saves fuel.  The above text says otherwise.)
Offline rodrigue
« Reply #12 on: May 12, 2008, 11:17:41 PM »
haha bro.. thks for typing the whole thing out.. i bet ours must be modern fuel injection engines.. think your answer clears all my doubts.. arigato!  ;D
« Reply #13 on: May 12, 2008, 11:21:51 PM »
No problem, bro.  Just copy type only.  Not I draft, hehehe.
Offline idiotboi89
« Reply #14 on: May 12, 2008, 11:29:53 PM »
ahha always thought its like manual, i step brakes, auto clutch in or something. no wonder got ATF..  :devil2: will go read up
Offline rodrigue
« Reply #15 on: May 12, 2008, 11:35:37 PM »
this piece of info is something good to share with newbies... agree?  :yehyeh:
« Reply #16 on: May 12, 2008, 11:43:20 PM »
Yep, no worry, everybody is learning everyday.  :D
« Reply #17 on: June 03, 2008, 11:19:18 AM »
yeap i think howstuffworks has a very good article on torque converter (the clutch equiv in AT gearboxes), read that.  :thumbsup:
Offline xuan511
  • Latio is a good car
« Reply #18 on: June 03, 2008, 01:50:48 PM »
I also thought got auto clutch lol~ so its a totally diff thing  :bleh:
Loving My Whitey
« Reply #19 on: June 03, 2008, 11:44:18 PM »
wat about switchin off the ignition while waitin for light to turn green?
