Author Topic: Window washer fluid reservoir  (Read 20114 times)
« on: June 10, 2008, 09:24:42 PM »
The window washer fluid reservoir, how do u check the fluid level, the manual says to use finger to plug the center hole of the cap/tube assembly, then remove it from the reservoir to check the fluid level?
Need to add fluid to what level? normal plain water also can add right?
i check the manual, it says add a washer solvent to the water for better cleaning?
pls help.
thanks.
Re: Window washer fluid reservoir
« Reply #1 on: June 10, 2008, 09:43:42 PM »
i don check, normally i filled till i see the water. just plan water will be good, was told by autosaver mech, if using silicon wiper, no need to add any cleaning solvent.
Offline xuan511
  • Latio is a good car
« Reply #2 on: June 11, 2008, 09:06:59 AM »
my friend added some cleaning agent which makes the water like foam wash
Loving My Whitey
HJB
« Reply #3 on: June 11, 2008, 09:48:13 AM »
If the window's very dirty, then it's good to have the cleaning solvent (like travelling in MY).
Offline xuan511
« Reply #4 on: June 11, 2008, 04:41:01 PM »
make sure its good enuff to remove egg whites/yolk
Loving My Whitey
« Reply #5 on: June 11, 2008, 07:48:57 PM »
hi ns
thanks, u r the 1st one to reply to me again (i remembered u did show me where it is during the meetup, u r so kind, i still remember until now. :)
your white hairs look cool :)
thanks buddy!
regards.
« Reply #6 on: June 11, 2008, 07:49:43 PM »
hi HJB
iagree. very dirty :( esply after we speed in HSHW!
HJB
« Reply #7 on: June 12, 2008, 09:09:09 AM »
hi HJB
Yup yup ... esp when it's very dirty and starts to drizzle ... not here not there.
« Reply #8 on: June 12, 2008, 11:55:27 AM »
Sigh.
I still got no time to topup the water yet! :( Sadness.
In SG, very susah!!!! In msia house, we can pour in anytime!!!
« Reply #9 on: June 12, 2008, 12:41:09 PM »
Use plain water enuff. Foam will make ur wiper stick. I think. heh...
Kena egg or what, pls go wash immediately. Because with wiper u wun be able to clean it off clearly. (Kena before...)  :(
« Reply #10 on: June 12, 2008, 02:59:07 PM »
kanna egg, the more you wipe, the more blur is it, whole windscreen turn blur till you cant see thru anything
« Reply #11 on: June 12, 2008, 04:09:51 PM »
In KL, it happened before...
Those ppl who intend to rape your car will throw egg to your windscreen. If you are unaware what things they had thrown to your windscreen & you quickly use the wiper to clean it off, you will be KENA! They use Egg because they want you to stop your car, you can't even drive your car because you are unable to see anything !!!
Scary!!!
Sorry, the correct word shld be to ROPE your car!
Regards!
« Reply #12 on: June 12, 2008, 04:10:40 PM »
NS, what u said is very true. It's a scary weapon!
« Reply #13 on: June 12, 2008, 08:27:51 PM »
Sigh.
When you go petrol kiosk, you can request the pump attendant to top up water for you.  :smile:
ahhoe
« Reply #14 on: June 13, 2008, 08:37:12 AM »
haiz... the attendent over at my SPC behind didnt even bother to clean my wind screen , let alone top water...
« Reply #15 on: June 13, 2008, 02:43:47 PM »
oh, gd idea.
that's lousy then.
o, i pump in msia petrol stn oni.
« Reply #16 on: June 13, 2008, 09:12:53 PM »
That is 1 of the reason why I sticked to Caltex.  :D
Offline zzzz
« Reply #17 on: June 14, 2008, 09:37:47 AM »
thanks buddy!
regards.
[/quote]
Sound bari gay ley...wha haha (joking only)
if u need to add cleaning solvent, do make sure that it is the pH balance type (those use for car wash).. if the ph is in balance, it will demange the paint work in long run....
Imaging, u leave the stain of the cleaing solvent on the bonnet and dry under ths sun....
hope that help...Cheers !!
Zzzz = z4
« Reply #18 on: June 14, 2008, 10:07:20 AM »
thanks buddy!
regards.
Oh, it's alright. No worry, i am not a gay :) Just a friend lah...!
So difficult, still need to check pH!!!
Offline zzzz
« Reply #19 on: June 14, 2008, 06:42:59 PM »
Oh...
not to check pH la...
generally all cloth/dishwaher are not pH balance...so if use, then no good...
Most of the car cleaning solvent should be ok...so that depend on what u add into the car.......
Zzzz = z4
