Author Topic: What is that yellowish thing under boot?  (Read 15168 times)
« on: September 23, 2008, 10:01:11 AM »
Does anyone know that yellowish thing under boot is?
Re: What is that yellowish thing under boot?
« Reply #1 on: September 23, 2008, 10:06:51 AM »
Hmm....didn't notice....later i go check and let u know....
Offline lyh1280
« Reply #2 on: September 23, 2008, 10:58:18 AM »
Strange, seems like the primer paints/sealants not painted/overcoat with normal top-coat grey paints..
Bro, is ur car new/or 2nd hand 1? Normally when we check for "accident-free" 2ndhand cars, this is 1 of the area we will check, to make sure all the joints/connection area is as original, no additional touch-up done..
If urs is new, since day 1 u notice this? Or is it TC does a touch-up without ur knowledge on 1 of ur service?
Simple...
« Reply #3 on: September 23, 2008, 11:31:12 AM »
lyh1280, is brand new, just collected. Why touch-up is required on brand new car? Should I make big noise to TCM? Can't believe it !!! Anyone could verify your boot and give your advice. thx...
« Reply #4 on: September 23, 2008, 11:44:49 AM »
The location is where u lifted up the floor mat of ur car boot right? will go check mine later when i go out for lunch and let u know later...
« Reply #5 on: September 23, 2008, 01:05:11 PM »
Just called my SE, he said if yours is "accident-free" car, u will have this sealants. If it is "accident" car, u will NOT have this sealants as this is not available in Singapore. How true it is? I'm worried now  :weep:
« Reply #6 on: September 23, 2008, 01:46:58 PM »
Just checked my car when i went for lunch just now...also have lei...when u got ur car? I got mine abt 5wks ago...
« Reply #7 on: September 23, 2008, 03:42:10 PM »
I got mine yesterday...  Finally :yehyeh: :yehyeh: :yehyeh:
Did you check with your SE see what the explanation is? My worry is like what lyh1280 said, something is wrong that's why they touch-up for us. And further more, brand new car shouldn't be "something wrong".  :mad:
« Reply #8 on: September 23, 2008, 04:17:05 PM »
hi all, my near 2 yrs latio also had this yellowish thing, so i assume all latio boot shld be the same, mine is sedan
« Reply #9 on: September 23, 2008, 04:49:21 PM »
mine also sedan...yet to check with my SE...will check with her later...
law
« Reply #10 on: September 24, 2008, 12:25:11 AM »
all cars have this. its to prevent water or air leak between overlapping panels. can be found in all panel joints like wheel arcs, floorpan, boot etc. not feasible to spray paint or touch up thus u see this "raw".
nothing to worry about. if u can't see this, then u should be worried  ;D
Offline lyh1280
« Reply #11 on: September 24, 2008, 01:18:36 PM »
Correct, all car shd hv this "connected/mended" joints, eg. at this car boot spare tyre area. But tink they suppose to overpaint it with the standard grey colours after sealing the joints.. if really condition as per from factory side/your picture, it seems "ugly" to leave it like tt, cannot be leh that Nissan so no standard on this simple issue.. shd hv overpaint it nicely.. :)
Btw, din c this in my Latio Sports year 07/2005 version..
Simple...
« Reply #12 on: September 24, 2008, 03:05:33 PM »
lyh1280, thx for the input, but u have confused me. "to make sure all the joints/connection area is as original, no additional touch-up done.."  SO, all brand new car should have this touch-up joints or only accident car? U mean u didn't see this in your Latio? Why some ppl have and some ppl don't?  :confused1:
Offline lyh1280
« Reply #13 on: September 24, 2008, 11:05:32 PM »
Bro,
Sorry for confusing u..  :smile: if there is such a joint/connection area, they must hv mended/sealed it up at factory side, then overpaint with nicely original paints. I am wondering if they actually add/seal somemore when the car is here.. cos Nissan Japan won't leave it like tt i tink (as per ur picture), i tink no standard leh.. prob u don hv to worry since some other members here has the same thing.. at least confirm ur car not accident car la..
Btw, I hv just re-checked again my boot/spare tyre area for Sports, i din c any joints/sealants leh.. the curve inside is so smooth, like they only bended/stamped deep in the tyre area, mayb there is joint further up at the level area but i coudnt c cos cover by the plastic parts already.. mayb l take some picture n let u all c..
Simple...
« Reply #14 on: September 25, 2008, 09:37:37 AM »
How do I check ah? Is it remove the boot floor mat exposing the spare tyre?
« Reply #15 on: September 25, 2008, 12:01:35 PM »
Yes alangohek, removing the boot floor mat, is at the spare tyre compartment. Let me know what u found. thanks.
