Author Topic: Blue Engine Oil Indicator Light  (Read 48834 times)
Re: Blue Engine Oil Indicator Light
« Reply #20 on: October 21, 2008, 05:49:17 PM »
on the A pillar ....  or u can choose to mount it under the HU unit , regretted which i never did.
u mean in front of the air con knobs???
can meh?
Jo_Lee
« Reply #21 on: October 21, 2008, 06:54:23 PM »
are those very colorful ones ? they glow in the nite like those i saw in those bengs' cars ?
me sua ku lah..didnt know that they are all gauges...thot some accessories to zhng the cars..btw, are they accurate
or juz good to have/good to look at ?
Offline sam
« Reply #22 on: October 21, 2008, 07:53:23 PM »
I mean the area right below the air-con knobs ( 90 degrees bend ) , but I wonder is it possible. These gauges are not for show.. the voltage one is wired to the battery terminals to measure it's voltage, and the water temp gauge, you need to install an additional item ( i forget that name leow) at the waterhose right out from the engine, thus measuring the temp. circulating the engine. They are lighted up with a tiny bulb within.
Yes, they look 'AH-BENG'  as what my daughter remarked, becos Latio sedan is uncle-look car, not-sporty looking and yet install these gauges ... heh very funny rite ? Who cares, as long as it serves it purpose.
Offline david1881
« Reply #23 on: October 21, 2008, 08:46:11 PM »
i check before with my se, she say nissan cars seldom have over heat problem
My Latio overheated twice!  :scared:
Finally TC changed the fan assembly.  Hopefully that's the last time....
« Reply #24 on: October 22, 2008, 12:28:54 AM »
To be on the safe side ( prevention is better than cure ), i installed the voltage & temp gauges.  :thumbup:
Same, I also installed volt and water temp meter, what brand you installed ?  :smile:
« Reply #25 on: October 22, 2008, 07:25:03 AM »
hi!
any picture of ur meter? care to share the damage?
thks
« Reply #26 on: October 22, 2008, 09:10:16 AM »
david, so car so new, only 4 months old, overheated twice ald ar? Overheated at checkpoint?
« Reply #27 on: October 22, 2008, 09:31:58 AM »
Serious? Your car so new also can overheat twice......scary sia....
Offline david1881
« Reply #28 on: October 22, 2008, 12:27:20 PM »
Ya, so scary.  :crying: At the checkpoint la.  Can't possibly stop the car right?  Everyone behind me will curse, swear and horn non stop!   Bo bian, just switch off everything (actually only aircon & radio could be switched off)  and still continue.  The light goes off when the queue move slightly faster.
« Reply #29 on: October 22, 2008, 02:46:07 PM »
Coming in Singapore or going out?
Offline david1881
« Reply #30 on: October 22, 2008, 06:24:21 PM »
Going out.
Only 15mins jam, that overheat light!  Imagine if 1.5hr????
« Reply #31 on: October 22, 2008, 07:11:12 PM »
Going out.
Was a hot day??
Offline sam
« Reply #32 on: October 22, 2008, 08:01:45 PM »
Going out.
You must check leakage if any / top up radiator water  N also Hose condition b4 driving into Malaysia.
Ah DONT FORGET to EMPTY YR BLADDER too.(U may wear pampers if wish to )... I kana once abt 2+half jam and once passed customs, sped to the nearest coffeeshop (lucky not far away), else did it at the lonkang.
Offline david1881
« Reply #33 on: October 22, 2008, 09:00:10 PM »
Was a hot day??
Yes, quite hot.  But whether hot or cool weather should not overheat unless got problem.
Offline david1881
« Reply #34 on: October 22, 2008, 09:02:15 PM »
Wa, u have good holding power!   :thumbsup:
Do you know they have portable toilet at woodlands side ?
« Reply #35 on: October 22, 2008, 09:35:03 PM »
hi!
thks
O.K, will try to take during weekend. During working quite rush.
Volts and Water Temp gauge cost $105 each plus a adaptor for water temp cost $25. Shop will fix for you at a norminal fees of $30 each gauge.  :smile:
« Reply #36 on: October 23, 2008, 10:08:59 AM »
Has your volt meter been accurate so far?
What's the brand?
My friend fitted a volt meter to monitor his battery but one night after he parked for an hour to have dinner, it failed to start despite the volt meter showing a good battery strength when he parked his car an hour earlier.
« Reply #37 on: October 23, 2008, 10:22:02 AM »
What's the brand?
Where ur friend did his volt meter? So tat we make sure we dun visit tat shop...
Offline spyder_696
« Reply #38 on: October 23, 2008, 10:44:00 AM »
When starting my car (Latio/Sedan/Premium) every morning notice there is one blue engine oil light. The manual says it lights up when engine oil is cold. Usually I idle for a few minutes on 'Park'  for the blue light to go off before putting the car on 'Drive'. Is it necessary to wait?
i never wait for the blue lite to go off every morning... once engine start... i rev all the way liao to office... there is no need to wait...
« Reply #39 on: October 23, 2008, 10:54:40 AM »
Hehe......actually i did the same thing since my first car, altis......at tat time...was more of a ignorant than bo chap....but later even when i found out....i also dun care....hehehe....i trade-in my altis when it was almost 3 yrs.....everything ok...except the interior starts to peel off.....lousy workmanship.....
