Author Topic: A/C not cold at 24 degree  (Read 23967 times)
Offline Toalson
« on: March 02, 2009, 05:00:11 PM »
Just wondering if anyone have similiar problems with the F/L. Prevously my temp settings were at 24 and it was cold air. Nowadays even at night, 24 it will blow out warm air. Have to set to 22 in order to achieve cold air. Is that a sign that my A/C is dying.... :(
Offline lgstan
Re: A/C not cold at 24 degree
« Reply #1 on: March 02, 2009, 05:14:44 PM »
if the aircon can blow out cold air ,the comp. is fine .maybe the sensor ba.
Offline Toalson
« Reply #2 on: March 02, 2009, 08:05:38 PM »
I hope so as well
« Reply #3 on: March 02, 2009, 08:31:26 PM »
hi!
wat i notice mine is when the weather is cold, the aircon not so cold leh. think mayb the sensor playing trick ba :confused1:
« Reply #4 on: March 02, 2009, 10:44:00 PM »
I experience it b4. Send to TC to reset your aircon, it works for me.
Our aircon is digital, so i guess need to reset it periodically? Like the way we reset our PDA which hangs occasionally  :confused1:
« Reply #5 on: March 02, 2009, 11:41:22 PM »
wats ur mileage like? can try changin ur a/c filter every 1Ok
« Reply #6 on: March 03, 2009, 07:54:21 AM »
His car is quite new.
« Reply #7 on: March 03, 2009, 08:04:59 AM »
hi!
It is not the sensor playing trick....it is the function of the sensor.....our car is JDI cars hence comes with a heater function for winter.....when you set a temperature lower than outside, it will blow cold air and when you set the temp higher than outside...it will become a heater and blowing hot air....so on cold days....set your temperature setting lower so that it will not be higher than outside temp...... :D
Offline Toalson
« Reply #8 on: March 03, 2009, 06:54:22 PM »
I did realised that whenever the difference between amb and preset temp is less than 2 degrees, the a/c would blow out warm air. However if the difference is more than 2 degrees is fine.
For example, recently outside temp is ard 25 and set temp is 24 I'm getting wram air. Worst of all recently even if the difference is more than 2 degrees, at my pevious preset of 24 I'm still getting warm air. :glare:
Offline Toalson
« Reply #9 on: March 03, 2009, 06:55:37 PM »
Thanks, oredi booked for a checkup on this sat. Now set temp and 22 and I'm getting coooold air...  :out:
Offline Toalson
« Reply #10 on: March 03, 2009, 06:56:20 PM »
You are correct.  :thumbsup:
« Reply #11 on: March 03, 2009, 09:15:34 PM »
hi!
when i did my 20k servicing, i complaint to them my aircon not cold. after that my aircon super cold. even these few days i set at 27 oso cold liao. today i et 27 abit too cold liao  :bleh:
« Reply #12 on: March 04, 2009, 05:38:42 PM »
hi Toalson
should turn on the A/C button right?
« Reply #13 on: March 04, 2009, 09:39:46 PM »
hi Toalson
Yo Bro,
You are funny.  :clapping:
Offline Toalson
« Reply #14 on: March 04, 2009, 09:51:44 PM »
hi Toalson
Wat do u take me for?  :glare:
Offline Toalson
« Reply #15 on: March 06, 2009, 03:09:47 PM »
Just did some trials and realised the problem with A/C only happens when using the climate control but when using the fan directly at 24 it still blows out cold air. Maybe that is also the reason why my SE told me to stay away from using the climate control. Anyone using the climate control and did not encounter the problem?
« Reply #16 on: March 06, 2009, 11:06:48 PM »
eh, sori har. wat is climate control har? our car got such function button har  :confused1:
Offline papajo82
« Reply #17 on: March 07, 2009, 08:41:33 AM »
I think he is referring to the auto button in the air-con control.
« Reply #18 on: March 07, 2009, 11:30:03 AM »
Side track a little:
I was driving with the windows down and aircon ON for a while. After that i wind up the window and white 'smoke' come out of the air vent, after a short while it stops. Anyone can describe this phenomenon?
« Reply #19 on: March 07, 2009, 04:19:46 PM »
Indeed it is....when you use the AUTO button on the climate control....the sensor in the
A/C will base on the temp u set against the temp outside & temp inside the car to decide the fan speed and cold or hot air to be blow.....but if u dun use the AUTO button and manually set the fan speed and temp, i think as long as the temp u set is below 26deg, cold air will always blow out irregardless of temp inside and outside the car......
