Author Topic: tyre recommendation  (Read 54013 times)
Offline winxp
Re: tyre recommendation
« Reply #20 on: March 12, 2009, 11:45:21 AM »
So when is the right time to change our stock tyres?
My ride is coming to two years this Sep and i am wondering if i should change the stock tyres since the general recommendation is 2 years. The stock tyres still look quite good but i understand that the lower end tyres normally last longer in terms of wear and tear but lose out in terms of performance and safety.
Always got this feeling that the car is taking a longer time to stop when i need to do E-braking even at a low speed so feel like changing to better tyres.
Is it a good time to get rid of the stock at 2 years irregardless of the condition? What good tyres are recommended? (looking at mid range ones that offer safety and comfort).
« Reply #21 on: March 12, 2009, 11:54:33 AM »
some ppl uses their mileage as a guage while some ppl change based on periodic. I tink if ur tyre tread is less than 1.6mm its more or less time to get a new set of fresh rubbers...
Offline kenmaine1008
« Reply #22 on: April 02, 2009, 06:42:18 PM »
Heres my FR after a few days of driving. Initially, I thought the tyres is a bit heavy, then I realise it is because the tyres got good grip(stick well to ground) thus the initial feeling, drove thru the heavy downpour yesterday and its  :thumbsup:. Not sure is it fair to compare to my stock toyo which already serve me for 45k km but the new hankook sure is quieter.
On a side note, the mechanic  pump 230 for both my front & rear tyres and I must say the extra air(for the rear) did result in better FC for me w/o any extra feeling of discomfort.
hmm.. is it heavier when u steer compared to ur stock? where do u change it?
Le Kua Simi? (x 2)
see my super chio rim~
Le Kua Simi?
my car more swee~
Offline spiff
« Reply #23 on: April 05, 2009, 06:59:44 PM »
Bridgestone GR 80 makes your car even quieter...try it
« Reply #24 on: April 05, 2009, 11:09:48 PM »
hmm.. hw much does it cost? the toyo stock really CMI...  :(
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
Offline tayyw76
« Reply #25 on: April 06, 2009, 12:02:52 AM »
GR 80 no longer in production, its replace by AR 10 which is made in thailand.. so y pay more for a japan brand tire that is made in thailand and not japan???
For me i will recommend u hankook optimo if u r a budget person or take V8 if u dun mind spending abit more for a better performance tire...
« Reply #26 on: April 06, 2009, 08:10:53 PM »
hmmm... they don take in the stock toyo tyres ah? any guys noe wht the stock rim is good? was tinking of changing both(tyres & rims) at next servicing....
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
« Reply #27 on: April 07, 2009, 01:15:36 PM »
Ken: Yes you are right bro. High Performance tires usually lasts longer, but the traction loses when compared to Ultra High Performance tires (within the same brand, there are still some rather pathetic Ultra High Performance tires around). Fyi, Turanza GR80, Hankook K415, Michelin Xm1 are High Performance tires. High Performance tires usually have a Traction of A, Temperature A and Threadwear index as high as 400.
The 1 thing which many drivers do not know is High Performance and Ultra High Performance. Many take brand and compare pricing, but this is wrong, they don't even research on what they are paying for. Ultra High Performance tires usually costs more because of the different compound and construction, else how can the tire tahan speeds of more than 300 kmh?
Ken: Yep, time to change the tires if i were you. Try to research on braking distance. In Singapore driving, short braking distance and good wet grip are priorities imho.
Ken: Its definitely a good mindset that you have to change regularly. Safety first! If not, it will be like parking coupons!! Save that bit of money if u heng, but once suay, not worth the ROI man!!
« Reply #28 on: April 07, 2009, 05:03:54 PM »
Are you an aggressive driver?
In what aspects do you feel the stock Toyo J50 tyres cannot make it?
It has served me well so far.
« Reply #29 on: April 07, 2009, 07:08:21 PM »
Hi clarence, wld u consider replacing your stock toyos j50, with another set of stock toyos j50 after ur current set wears off?
« Reply #30 on: April 07, 2009, 08:57:05 PM »
i'm not an aggressive driver.. but as u noe.. some ******** drivers like to cut into ur lanes suddenly which nid u to e brake... juz haf this feeling that the car might not always be able to stop in time...
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
« Reply #31 on: April 07, 2009, 09:17:03 PM »
information on sidewalls of Toyo tyres - Treadwear grade 220, Traction grade A, Temperature grade A
if Toyo tyres are really so bad, then how is it that these tyres are rated thus?
see page 9-10 Technical information of owner's manual for more information
may be good to conduct some "straight-ahead braking traction tests" one of these fine days to settle this matter once and for all
« Last Edit: April 07, 2009, 10:05:59 PM by Silver »
Offline CADesign
    • CAD Design Racing Wheels
« Reply #32 on: April 07, 2009, 09:43:12 PM »
How abt Falken ZE912?  Cheap at $80/pc.
For Hankook, I understand can get cheaper in Msia.
yea korea tyre cheaper in msia.. 912 is a great tyre offered at good price
www.RM-TeamRims.com
Cheng An Da Pte Ltd - Specialist in Sport Rims and tyres
10, Kaki Bukit Road 1, #01-18
KB Industrial Building
Singapore 416175
http://forum.thelatioclub.org/index.php?board=40.0
« Reply #33 on: April 08, 2009, 02:09:59 AM »
Definitely, I would use Toyo J50 tyres again!
In fact I recommended my brother-in-law to use Toyo J50 on his Fiat Doblo which uses the same size 185/65R15 as Latio.
His previous stock tyres were Pirelli Cinturato P4 before he switched to Toyo J50. It has been 6 months and he is happy with his new set of Toyos.
Great value at $90 nett a piece and made in Japan.
Most tyres are now made in Asia (cheaper labour and material cost) and yet cost even more than the Japan made Toyos.
http://www.tyrepac.com/Form/B2C/Home.aspx?type=TyresSearch&width=185&size=15&profile=65&season=all&brand=All&source=Home
« Reply #34 on: April 08, 2009, 11:01:59 PM »
Are you sure you can get brand new J50 tyre in the open market ?
« Reply #35 on: April 08, 2009, 11:20:11 PM »
very good...
support!
Offline wytan
« Reply #36 on: April 09, 2009, 12:24:44 AM »
Anyone going to try the new Michelin Primacy LC?  :bleh: Replaces the Energy MXV8.
http://www.sgcarmart.com/news/article.php?AID=2031
Don't know made where also.. Thailand? India? Seems like got some ppl running it in India liao.
« Reply #37 on: April 09, 2009, 01:03:59 AM »
hmm.. rather confused by so many pple with so many recommendations.. toyo J50 vs. Hankook K415 vs. Hankook V2 vs. Michelin Energy Saver....  :confused1:
Le Kua Simi? (x 2)
Le Kua Simi?
my car more swee~
Offline nymin9
« Reply #38 on: April 09, 2009, 09:30:42 AM »
i didn't really like 912 cos seems harder to brake although i have changed to 912 16/205 from v2 15/185. v2 seems to be more "responsive" in braking.. like sticky-er
To Lead is to Serve!!!!
Offline vortex
« Reply #39 on: April 09, 2009, 10:37:24 AM »
I'm actually in favour of the falken 912. Upgraded from my stock toyo to the 205/50 R16 about a month ago. Better grip on the wet road, esp experienced it during these few weeks of heavy downpour, better comfy in terms of noise level and better stability and less bouncy.
