Author Topic: how to switch on fog light on latio cvt sedan?  (Read 12827 times)
Offline foofam77
« on: April 05, 2009, 10:20:57 PM »
pai seh, any idea what i shd do to on my fog lights?
thanks
Offline leolooi
Re: how to switch on fog light on latio cvt sedan?
« Reply #1 on: April 06, 2009, 11:02:14 AM »
u mean how to switch it on?....tot there is a knob to turn?...or you mean smetin else..... :confused1: :confused1:
turret
« Reply #2 on: April 06, 2009, 12:21:06 PM »
Anyone care to share whether the outside workshop install fog light for latio including wiring and the switch?
In comparison, anyone knows how much does it cost to do it at TCM?
BTW, mine is a normal latio sedan which does not come with fog light.
Thanks.
Cheers.
LaChio
« Reply #3 on: April 06, 2009, 02:30:50 PM »
thanks
Check with LTA or TP whether fog lights are allowed at that particular time. Understand fog lights are not allowed under normal conditions unless very heavy rain or very bad visibility.
If you mean how to switch on the fog lights, the knob is in the same lever as the normal headlights. The outer knob on the lever is for the headlights and the inner knob is for the fog lights. There's an indicator on the dashboard if the fog lights are switched on.
« Reply #4 on: April 06, 2009, 05:08:56 PM »
Thanks.
Cheers.
Yes it comes in a whole assembly includin wirin & switch, definetly much much cheaper doin it outside. . .
« Reply #5 on: April 06, 2009, 05:11:14 PM »
thanks
You have your latio for 2 yrs liao, finally got chance to use fog light.. Very heavy rain yesterday..  ;D
Offline foofam77
« Reply #6 on: April 06, 2009, 06:38:33 PM »
yeah, i donoe where the switch is located..pardon me pls
turret
« Reply #7 on: April 06, 2009, 08:16:41 PM »
hi, any cost estimate for a full set for everything? how abt the existing black bumper to house the fog light? need to change  the whole bumper or cut 2 holes only??
need to start saving monies for next upgrade.... :bleh:
« Reply #8 on: April 09, 2009, 08:09:56 AM »
You can on the fog light only when you on your head light (can either on the dim or bright head light).  You cannot on the fog light without switching on the head light.
« Reply #9 on: April 09, 2009, 09:45:32 AM »
refer to this MO
http://forum.thelatioclub.org/index.php?topic=7239.0
heard outside workshop, it will required a manual switch to on the fog lamp. not like original  CVT one
Offline foofam77
« Reply #10 on: April 09, 2009, 07:39:42 PM »
yes i know :)
but after switching on the headlight, which part of the lights knob shd i turn to?
Offline Toalson
« Reply #11 on: April 11, 2009, 09:52:45 AM »
On the same light switch stalk. Tats' for the FL
Offline foofam77
« Reply #12 on: April 11, 2009, 02:51:38 PM »
switch stalk?  what sort of symbol is that?
sorrie for such goondo question..
Offline wytan
« Reply #13 on: April 12, 2009, 12:46:16 PM »
The middle of the signal stick can adjust one.. Just like the wiper intermintent speed.
The middle of the signal stick is to switch on/off the fog light. If the switch is on, the fog light will turn on once you turn the headlight switch to any position other than off.
 :smile:
Offline Toalson
« Reply #14 on: April 13, 2009, 10:28:03 PM »
Me bad, it should be light switch stalk or stick as another bro mentioend.
