Author Topic: Which Brake Pad to use???  (Read 21443 times)
Offline SpeedLimit
Re: Which Brake Pad to use???
« Reply #20 on: April 21, 2009, 01:14:04 PM »
Change both front and rear brake pad at AS last week.
Now there is a tick tick sound from the drum brake during braking, went back to AS and they say this is normal as new brake pad is uneven and sound would go away once the wear and tear set it.
True? :confused1:
True. i change at AS recently also
but AS brake pad not cheap. cost $135...
« Reply #21 on: April 21, 2009, 01:41:55 PM »
Thanks bro. Yah, the front disc pad cost $135 and the back ones cost $125 a pair  :scared:
« Reply #22 on: April 21, 2009, 02:16:57 PM »
bro, wat u mean by cross drilled slotted?
btw, i have change my brake pad and how do we know when the brake pad wear off?
accident?  :D joking...
the disc rotor has holes and slots.
how to know? can see the depth of pad left.
« Reply #23 on: April 21, 2009, 02:17:38 PM »
sounds exp.
« Reply #24 on: April 21, 2009, 03:32:55 PM »
Depends on the rims design leh, some difficult to see wor.  :unsure:
« Reply #25 on: April 21, 2009, 08:00:13 PM »
then remove pad during servicings.
« Reply #26 on: April 22, 2009, 08:40:16 AM »
sounds exp.
Yeah, its exp alright. But no choice, left with only 20% of brake pad, safety should come first.
Btw, any recommendation for cheaper stock brake pads (both disc and drum)
« Reply #27 on: April 23, 2009, 11:07:26 PM »
EBC green/yellow brake pads gD stuffs
adbie
« Reply #28 on: November 01, 2009, 11:34:02 AM »
The temp spec. affects its endurance...higher the temp u can brake at high speed frequently..usually 400"C is enough for our Latio
Can try Bendix and Fuji..
I recently changed my brake pad and has been experiencing the same brake dust problem ("matte" rims after 1 day).
Do Fuji brake pads produce less brake dust?
I also heard about "brake shields" - are they useful?
As I'm a total newbie to car servicing and brake pads  :nonod:, would greatly appreciate if someone can kindly recommend a good not-too-dusty brake pad (Fuji? which model?), brake shield (if any), and a workshop that carries them (preferably in the East).
Thanks a million!
