Author Topic: Latio rear always kana kerb?  (Read 40115 times)
Offline SpeedLimit
Re: Latio rear always kana kerb?
« Reply #20 on: May 03, 2009, 04:21:40 PM »
As our tip is pointing downwards, higher chance of hitting kerb.
but if to cut off the tip and weld a straight tip onto it,will it be better?
legal anot?
« Reply #21 on: May 04, 2009, 11:51:38 AM »
legal anot?
changed at tcm.  so far the spring is stiffern now.  no more kena curb
the SA told me latio spring is a soft type for comfort ride.
Date: 02 May 2009
Invoice Amount: $ 0.0
Invoice Date : 02 May 2009
Job No : HG512051
Job Status : Completed
Mileage : 19755 km
-   CHECK REAR SUSPENSION ALWAYS HIT EXHAUST -RENEW BOTH REAR COIL SPRING
Offline alghojo
« Reply #22 on: May 04, 2009, 04:20:06 PM »
Will do this on my next servicing.
« Reply #23 on: May 04, 2009, 05:28:10 PM »
just tell the SA the rear suspension problem.  He will change for you.  No questions asked. the service Adviser (Ubi) is ThomasTan. very friendly
gd luck
Offline kenmaine1008
« Reply #24 on: May 04, 2009, 08:40:51 PM »
gd luck
hmm.. den hw was ur ride after the change? is it comfortable? or more stiff now? feel like doing for my next servicing too.. but don wanna compromise the comfort too
Le Kua Simi? (x 2)
see my super chio rim~
Le Kua Simi?
my car more swee~
Offline alghojo
« Reply #25 on: May 04, 2009, 09:05:35 PM »
gd luck
Too bad, i do my servicing at BT cos nearer to my place. Anyway, will bring up the matter on my next servicing.
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
« Reply #26 on: May 27, 2009, 09:24:01 AM »
i change the shock absorbers behind....now so much better , pass hump dun feel like car bottoming out, the spring change is also another good idea, cause its free.
Offline petra74
« Reply #27 on: June 17, 2009, 05:35:39 PM »
not only rear, the front also very low.
beware not to park head in also
my front kena and drop out when head in.
I for one can testify, I parked head in at Suntec where the lot got one metal bended pole kurb, I heard and felt that my front bumper rubed against it. So I reverse and heard another loud sound, lo and behold, my front bumper came out... yes, mine is bodykit which came with it when I bought it... Nissan Latio Sedan... Premium.. haiz.. got to be careful... our cars are pretty low...
"... for King and Kingdom..."
« Reply #28 on: June 17, 2009, 06:32:01 PM »
was told by the SA is better not to park head for latio.  the front bumper is quite low esp those with DS3 body kit.  if need to , don;t move too close to the curb.
if really need to park head.  best to install a front parking sensor for detecting the curb
Offline petra74
« Reply #29 on: June 18, 2009, 05:12:58 PM »
Installing front bumper sensor may be a good option too, like eating at Siglap area, you will need to park head in most of the time unless I park behind... anyone know how much does it cost to install sensor at the front?
Offline rayace168
« Reply #30 on: June 18, 2009, 05:17:13 PM »
without bodykit will also hit hor. very stock, no DS3 or whatever kit.
I kena before, bumber was pull out a bit and left an opening to the attached seam on left side front.
so it's better to hit the back than front bcos it will pull out if u heads in.
My advice for solution if u have some money to spare is get a reverse camera and judge from the screen which i always do.
« Reply #31 on: June 19, 2009, 09:19:42 AM »
if you park head, don;t think reverse camera can see
Offline rayace168
« Reply #32 on: June 22, 2009, 01:48:25 PM »
right, lesson taught me not to head in.
just do reverse parking.
at least yr bumper is safe from pulling out.
« Reply #33 on: June 22, 2009, 03:53:31 PM »
well, mine already pull out once and the front view looks "lower" than stock.
Offline rayace168
« Reply #34 on: June 22, 2009, 06:47:54 PM »
any opening seem on the seam? if not, then should be ok.
looks "lowered" can look nicer.. ::)
Offline SpeedLimit
« Reply #35 on: June 23, 2009, 12:23:32 AM »
Lower or drop??? hehe
my advise is never park head in...
my bumper is secured back after it fall off
bumper if 'force secure' back only
« Reply #36 on: June 23, 2009, 10:39:13 AM »
no break no seam no drop. the lowest black colour portion of front bumper got "pulled down" a little. no so curve in as original condition.
Offline MadMatty
« Reply #37 on: June 28, 2009, 11:22:33 AM »
My front bumper already many scratch mark and at two front corner paint peeling out... :crycry:
« Reply #38 on: June 28, 2009, 06:16:11 PM »
possible to ask TCM to adjust our suspension to lift the front up???
but lift up = not nice leh :crycry:
Offline limcheemeng
« Reply #39 on: June 29, 2009, 11:00:28 PM »
Date: 02 May 2009
Job No : HG512051
Mileage : 19755 km
How is your ride with the new coils? Less comfy?
