Author Topic: steering wheel so hard to turn.. HELP............  (Read 20487 times)
baggiohuei
« on: September 10, 2008, 09:03:25 AM »
bros...
recently send my car to TCM, claim that the car easily drifting to left,and they promise me will do something on it. But after i collect the car, i feel the steering is damn heavy and hard to turn. especially when make U turns, it make me feel bit tricky because the steering wheel springs back to centre too eagerly. totally got no ideal wat had they done on it. does anyone meet this kind of problem before? is this normal? help if anyone get some ideal...
thanks
Re: steering wheel so hard to turn.. HELP............
« Reply #1 on: September 10, 2008, 09:44:13 AM »
GO BACK TO TCM !!!. You should have highlighted it to them the moment you  collect your ride.
« Reply #2 on: September 10, 2008, 11:02:49 AM »
Me also send in the car for servicing today..
Issue list,
1) Steering wheel coupling - Changing
2) Car drifting left.. - donno what they going to do
3) Rear suspension squeeky noise when going over hump - change both rear suspension coil.
4) Air con cranky, not cold.. - donno what they going to do.
later going to collect at Lok Yang, was promised car before 5 pm.
« Reply #3 on: September 10, 2008, 02:10:25 PM »
It is a concern that so many Latio owners are having their relatively new faulty steering coupling changed during the warranty period.   :crying:
What is the main function of the steering coupling and where is it located?
Latiorarri,
How old is your Latio?
« Last Edit: September 10, 2008, 02:12:14 PM by clarence »
« Reply #4 on: September 10, 2008, 03:04:33 PM »
Latiorarri,
My latio is ~ 7mths old, did about 17000Km liao..  seems it's a batch related issue?? According to SA, this part being replaced will be an improved part. Late will go and ask more.. car ready liao.. leaving office earlier to go collect. will update more tonight.
« Reply #5 on: September 10, 2008, 04:46:04 PM »
This is really scary...my latio is abt 1 mth old....so far it has served me well....but i do have a bolt that rust very badly...when you open ur bonnet, there is a bolt on each side of the front at the side of the lining....I am going to send it in to them tis sat to check..also the rubber sealing right at the back of my wind screen was tucked in....hope it dun cause leakage....also, the UV protector thing got quite a bit of bubbles on the side window and 2 scrap mark (probably when they stick the UV protector sticker) on the front wind screen...sian..
« Reply #6 on: September 10, 2008, 09:17:20 PM »
Okay folks... erhh this a bit off topic... but i got back my car liao..
1) Steering coupling changed.. car's fine now
2) 2 rear shock absorbers changed .. no more squeeky noise
3) re centred steering wheel, no more difting to left.
4) tighten/adjust belting, no more squeeky noise from the rotating parts.
5) Air con cranky, Ambient temperature sensor not working properly, replaced.
actually the car is fine.. i've been a bit rough with it lately.. so feeling guilty then today eng so i sent the car in for servicing.. the only big issue i had was the steering wheel coupling the rest i just added in see what TCM will do.. i got all my issues fixed. car was actually ready at 1pm. but i din have time to go collect.
 :yehyeh:
« Reply #7 on: September 11, 2008, 09:48:21 AM »
Glad that they fixed the faults for you, but am surprised that so many problems have surfaced prematurely in a 7 month Latio.  :unsure:
Offline fickle
« Reply #8 on: September 11, 2008, 01:26:55 PM »
so wat is this coupling thingy for?
baggiohuei
« Reply #9 on: September 11, 2008, 03:53:52 PM »
Hi Latiorarri or anyone here...
how do we know the steering wheel coupling needs to be change? any symptom will let us know in advance?
since you already change new set, how you feel on your car handling? easy to turn the steering?
thanks...
« Reply #10 on: September 11, 2008, 03:58:12 PM »
You will hear a "Kiak Kiak" sound when you turn your steering wheel or when driving in a straight line.
Offline fickle
« Reply #11 on: September 11, 2008, 06:55:01 PM »
does the sound become worse with time?
Bilancia
« Reply #12 on: September 12, 2008, 12:39:08 PM »
I think something wrong with the steering pump. I advise you that come by our work shop at
48 Toh Guan Rd East
#01-111
Enterprise Hub
www.bilancia-intl.com
and have a check on it. We dun charge if we dun reolve.
Offline aerosignal
« Reply #13 on: September 12, 2008, 12:55:59 PM »
48 Toh Guan Rd East
#01-111
Enterprise Hub
Good offer get a second opinion.
Just a note, our car don't have steering pump.... Electric motor assisted power steering... cheers
« Reply #14 on: September 12, 2008, 07:58:12 PM »
He should know since he is ex-Nissan chief mechanic IIRC.  :smile:
« Reply #15 on: September 12, 2008, 11:17:19 PM »
thanks...
Actually if you haven felt it by now it's shows that your steering wheel coupling is working fine  ;) i actually feel it more then hear it. I could 'feel' my steering not smooth when turning.. espcially so when going up/down MSCP. at time a soft sound like something knocking will accompany when i turning or returning my steering wheel to centralised position.
Offline fickle
« Reply #16 on: September 12, 2008, 11:27:12 PM »
i haven't felt the steering being hard, but do notice a very soft "knocking" sound at times when i return the steering wheel to centre after a right turn at slow speeds, especially during parking.  Tried turning to the left but no sound. Din think much of it at first until i saw this thread.
« Last Edit: September 13, 2008, 05:04:53 AM by fickle »
baggiohuei
« Reply #17 on: September 13, 2008, 08:40:34 AM »
just wonder why the ******** steering so heavy to turn and called to TCM yesterday, request them to check again,see whether can they do something to make my steering become lighter. will update you all later. GOD BLESS ME :(
Offline aerosignal
« Reply #18 on: September 13, 2008, 08:49:47 AM »
I am sure Hussein knows. Don't think it was Hussein who posted the advise though. I believe several of his staff post from that nick. Don't think they should be shooting from their hips. Not good for Hussein's reputation. :thumbsup:
Offline elton_897
  • DUN LOOK @ ME I'M SHY
« Reply #19 on: September 13, 2008, 12:05:22 PM »
Steady i totally agree hehe.
I do have this steering problem too.
Been solve for 3 years end up give up liao.
I find that it should be the design fault as the noise will come back again.
I'm a vegetarian. I only eat animals that eat vegetable
