Author Topic: Change Latio Air Con System  (Read 43469 times)
Re: Change Latio Air Con System
« Reply #20 on: November 03, 2008, 04:02:44 PM »
Yes, my Latio has exactly the same symptoms as yours.
I wonder if this is normal or if there's gas leakage?
Offline vypez
    • need help with words?
« Reply #21 on: November 03, 2008, 08:07:19 PM »
its just the compressor going on and air con gas released to make it cold.
eh, i thought you expert in engine oil and audio? never go read up on air con ?
« Reply #22 on: November 03, 2008, 11:42:14 PM »
Hv exp b4 in my previous 16.5 yrs Corolla car whereby hs changed almost the whole air-con system (of course not all at the same time lah), 1st. the air con compressor -> replaced in JB but 2nd hand part from Sg (cost me ard RM$800), 2ndly, changed all the piping due to some leakage (cost me another RM$300), 3rd, changed the fan coil unit (original in Malaysia, Tangkak, near Malacca) due to small leak at RM$350 (thanks to the boss of the workshop as he is very Kind and not simply over charge me with my Sg plate). By the way, noticed many friends of mine (local), do not bother to check if the air con is in good conditional, they just simply leave it to SA during service (also not sure if the air-con been checked during service). It's advisble to get the air con check at least one a yr.
« Reply #23 on: November 04, 2008, 08:00:01 AM »
Is there any particular symptom that we can aware of ? Thanks.
JM
« Reply #24 on: November 04, 2008, 09:34:34 AM »
I changed the compressor, air con coil and about everything related to the air con for S$1845 over the Deepavali weekend.
« Reply #25 on: November 04, 2008, 10:39:54 AM »
Did you change it at Tan Chong?
What car are you driving?
« Reply #26 on: November 04, 2008, 01:48:57 PM »
Hi JM
So expensive? Where did you change it?
In other word, you change the whole aircon system.
« Reply #27 on: November 04, 2008, 11:07:07 PM »
for me, the air con can't really generate cool air during idling (eg waiting at traffic light). Understand that it's a symptom of
not enough gas which eventually will damaged yr compressor. Must send for check up and not to wait for any longer (or should stop using air con untill everything been rectified).
JM
« Reply #28 on: November 05, 2008, 09:57:48 AM »
I changed it at TS Auto. I am drive a Latio 4AT.
« Reply #29 on: November 05, 2008, 12:04:44 PM »
Difficult to endure if stop using air-con inside the car.
« Reply #30 on: November 05, 2008, 12:10:02 PM »
Worst case scenario, you can turn it to high speed fan mode and adjust circulation air flow to allow to flow into cabin from outside.
This helps to disperse the built up heat on the cabin when waiting at traffic lights.
But once you drive, the air will flow in from the opened windows.
« Reply #31 on: November 05, 2008, 01:18:58 PM »
yup, but dun do this if there is a rubbish truck in front of your car.  :bleh:
i ever experience air-con gas empty when coming back to singapore from jb at the causeway driving my previous car, can hear hissing sound constantly thus full blast the fan w/o aircon mode, but still sweat lah as jam mah  :(
Offline MadMatty
« Reply #32 on: November 05, 2008, 09:05:09 PM »
My Latio air con system emits a hissing sounds when I turn it on.
Could there be a possible leakage?
mine also loud hissing sound when first on but the sound comes from outside the compartment from the engine compartment but sound dies off after a couple of second...what i mean hissing sound if there is a gas leakage is from the condenser unit inside the driver compartment...this is normally on switching the a/c on..the hissing sound is due to the leakage gas rushing out against the metal fins in the condenser unit and also normally follow by a foul smell...
one other thing, I was told by those guys from car workshop that one of the causes of air con leakage is due to blockage of the drainage and this is actually cause by those car purifier...as the air con absorbs in the air and recycle...over time the purifiers particles will build up in the drainage system resulting in a choke drainage...
Offline phant
  • LATIO ALL THE WAY
« Reply #33 on: November 06, 2008, 10:08:53 AM »
If ur car is cold after topping up gas but few days later not cold again.
I afraid you might have the same problem as me.
They found the AIR CON COOLING COIL ASSY to be faulty.
So far, I have changed the air-con cooling coil, the AIR COND COMPRESSOR,
- AIR COND CONDENSER ASSY and RENEW COMPRESSOR ASSY.
But still i got this problem.
Francis aka phant
« Reply #34 on: November 06, 2008, 11:33:07 AM »
Hi phant
aircon cooling coil assy faulty? under tcm warranty for how long? can chg foc?
Offline phant
  • LATIO ALL THE WAY
« Reply #35 on: November 06, 2008, 02:58:10 PM »
Hi phant
wITHIN 3 YRS AFTER PURCHASE.
Standard warranty
Francis aka phant
« Reply #36 on: November 06, 2008, 03:04:05 PM »
Standard warranty
hi phant,
thanks. gd info.
Offline silver06
« Reply #37 on: January 21, 2009, 01:47:48 PM »
Hi guys,
Need help, my car aircon last week also have this hissing sound. After topping up the aircon gas, it reduce........ but today when I turn on the aircon the hissing started to come back...
How you guy resolve the problem or any workshop to recommend??
 :crycry:
Offline legan
« Reply #38 on: January 21, 2009, 02:41:07 PM »
I had the hissing sound before. TC changed the regulator and the problem is gone ever since.
Offline jalan
« Reply #39 on: January 21, 2009, 04:48:18 PM »
my new 2.5 months latio few days ago air con suddenly become less powerful .
last time fan speed 1st or 2nd bar fan quite strong n cold... now 1st speed like damn weak...
any latio owner have same experience ?
Is it aircon filter choked?
not going to TC workshop these few days, I believe their schedule are fully packed before CNY.
