Author Topic: Any experience with spring stiffeners ?  (Read 62313 times)
Offline gh05tss
Re: Any experience with spring stiffeners ?
« Reply #60 on: January 14, 2009, 10:06:05 PM »
Are we talking about this?
« Reply #61 on: January 14, 2009, 10:24:29 PM »
« Reply #62 on: January 14, 2009, 11:05:50 PM »
when ask tcm anythings they sure say cant do this cant do that will void warranty but this is normal to all car agents. So maybe can fix 1st when any problem occur just go outside workshop undo 1st then go back tcm for checking.
Yep, you are right.  ;)
melvinhgf
« Reply #63 on: January 14, 2009, 11:56:30 PM »
Yesterday went to Ubi TCM to check my wheel alignment, so while highliting, I asked the SE about the spring stifferner, he advise me against as this will compromise ride comfort plus shorten the lifespan of the suspension, worst still is, it ,may void the warranty by Nissan, I like sian 1/2.
Hmm i ask the same qn to the SE at TCM Ubi. He never mention about the voiding of warranty. Why shld warranty be void when u just add pieces of rubber/silicon?? The one i spoke to simply tell me that it is not needed for the Latio as the backside is already high so not likely will experience hitting the undercarriage. It is the Slyphy that requires the stiffeners.
He also said that so many people complain about this problem. It is a standard feature of japanese car according to him. because japanese go for ride comfort hence the cars are lower and more springy.
Then the Autobac Ubi mechanic told me that the stiffeners are good as it protects the suspension from damage due to excessive crossing of humps. So between ride comfort, and height of backside and suspension protection, one has to choose either and not both.
Offline gh05tss
« Reply #64 on: January 14, 2009, 11:59:20 PM »
yup
How the hell the SE say this will void the warranty, it like a dampener for your suspensions. It suppose to help you n yr car to cushion during humps n uneven when u on the road.
 :out: SE  :out:
« Reply #65 on: January 15, 2009, 11:27:13 AM »
that's right.  just look at the damper as part of the spring.
Offline gh05tss
« Reply #66 on: January 15, 2009, 12:18:52 PM »
You are right my neighbor :thumbsup:
« Reply #67 on: January 15, 2009, 10:08:37 PM »
The SE just mentioned it may void the warranty by the manufacturer and not by TCM. Although our Latio seem high, but the suspension is too soft, you never encounter kena your tow hook or maybe scratch your tip of your exhaust during reverse parking before when you ferry passengers behind.
melvinhgf
« Reply #68 on: January 16, 2009, 12:30:38 PM »
Erm.. i rarely ferry people around... and so far lucky for me, never kena the tow hook or exhaust (i tink)...
So thats y i install the stiffeners already... all four wheels! dun wan these to happen at all
« Reply #69 on: January 17, 2009, 01:17:25 AM »
 :thumbsup: Good .... at least you will not feel the pain.
Offline legan
« Reply #70 on: January 20, 2009, 09:16:31 PM »
went to Autobacs today and saw only size B left. Is it size A or size B anyway?
 :blink:
« Reply #71 on: January 20, 2009, 10:55:49 PM »
 :blink:
Which branch? Thinking of going tomorrow.
melvinhgf
« Reply #72 on: January 21, 2009, 08:40:11 AM »
 :blink:
Just tell them that you are unsure and ask them to check for you. If you trace back my posts, mine's size A whereas there are cases where size B and even C were sold to Lations.
Think the stores going to replenish in Feb. Tats wat the autobacs ubi pple say when i go and install beginning of the month. took all the size As away.
