Author Topic: car shaft spolit. under warranty by TCM?  (Read 27017 times)
Offline kennytoh
« on: August 09, 2009, 12:35:17 AM »
Hi, does anyone encounter "kok kok" sound when full turning of steering wheel during reversing?
ask a few of my frzs to sit in n all said it might be the car shaft spolit.
n the sound will get louder as time go if i dun repair it
Is it under warranty by TCM? my car is only 9 mths old.
heard the replacement costs is very high
n my frz said normally if i inform the techician during servicing, they will just spray oil to remove that sound temporary (which doesnt solve the problem)
Re: car shaft spolit. under warranty by TCM?
« Reply #1 on: August 09, 2009, 01:39:54 AM »
i having the same problem when down tcm servicing told them, they change for me free under warranty  :(but now the problem is back.  :(
Offline idiotboi89
« Reply #2 on: August 09, 2009, 04:39:58 AM »
is it the steering coupling that was supposed to be very common for latio? .. for me used to have until like gone liaoz.. didnt bother to go back change last time as i read in the forum that someone said it might come back .. and it pose no serious issue.. i might be wrong though.. =)
Offline pmet
« Reply #3 on: August 09, 2009, 07:41:00 AM »
Very common. I just changed mine 4mths back, tested no sound but now the sound is back. The mechanics know if you tell them steering coupling. Think they close one eye also can change for u liao.
Offline Novellus Legends
  • Eye Power !
« Reply #4 on: August 09, 2009, 10:45:34 AM »
I heard they just do greasing instead of replacement nowadays thus explains the reoccurence.
Me&my TiidaLatioZ
« Reply #5 on: August 09, 2009, 01:17:00 PM »
Kenny,
No harm if Tan Chong just oils the affected part.
If problem persists, tell them oiling did not help and request for replacement of affected part.
Your car still has over 2 yrs of warranty left so its OK.
Offline kennytoh
« Reply #6 on: August 10, 2009, 09:22:18 PM »
thank you all for all your replies.
that's wat my frz told me, normally they will just put oil to remove the sound which does not solve the problem.
he asked mi to insist for a replacement if the problem come back again before the warranty is over, because the cost of changing shaft is few thousands dollar.
my gf also facing the same problem in the pasts. she said the sound will get louder n louder if u ignore.
i did some google search on this n found this msian forum for latio.
1. Knocking sound while turning steering (Nissan would replace coupling, FOC, it's a manufacturing defect)
=> These symptom starting to occur slowly. I getting to know more and more latio's owner having the problem when turning the steering.
=> Solution. They complaint it to TCEAS and they replace the whole steering rod which they ordered from japan/thai. Once replaced, some 100% solve and some still claim got sound - but softer. So far, I have not encounter these problem yet *touch wood*.
http://www.motortrader.com.my/asp/forum/topic.asp?TOPIC_ID=32368&#469911
pmet: is steering coupling the same as shaft coupling or etc? sorry, not really gd with the name of the car parts
Offline pmet
« Reply #7 on: August 11, 2009, 12:43:19 AM »
yup steering coupling = steering shaft coupling or shaft coupling
Offline pest11
« Reply #8 on: August 11, 2009, 08:16:53 AM »
ha ha .... car now 2.9yr-old .... last wk just replaced 5th set of steering-coupling (*me very sensitive to this problem !!) ... each time the SA say it's a new improved one  :confused1:, ...... btw, each replacement will have "6mths warranty" .....
Offline kennytoh
« Reply #9 on: August 11, 2009, 09:45:42 AM »
pest11: hi, how long do they take to change the steering-coupling? few days or few hrs?
pmet: thanks
« Reply #10 on: August 11, 2009, 10:00:00 AM »
Hi, is your car park a open or multi storey carpark ?
cos under the multi storey carpark , you need to turn the steering wheel to move up to next lvl, it may stress your  steering wheel after a period of time
just me opinion only
« Reply #11 on: August 11, 2009, 10:08:07 AM »
sigh, mine oso having the same problem again. this friday when do servicing must ask them to change  :mad:. but that still wont solve the root problem. maybe another 6 mths + need to change again  :mad:
Offline kennytoh
« Reply #12 on: August 11, 2009, 10:33:43 AM »
mine is open carpark.
there's a few times which i hit the end when i turn the steering too fast. but my frz told mi that it wont be so weak to make it spolit with that few times.
he also told me that normally the technician will just spray oil to remove the sound temporary which doesnt solve the root problem. coz seriously, even if they spray oil but tell u that they had replace a new one...u also dunno, also lan lan coz they prove to u the sound is gone (which is due to the oil).
Offline skxly
« Reply #13 on: August 11, 2009, 11:05:33 AM »
My ride also "kok kok" when reversing - thanks to TS as this is a good reminder, my 10K servicing is coming up.  Sigh .... brothers and sisters who suffer from the same defect, please highlight the defect on the TCM feedback survey.
« Reply #14 on: August 11, 2009, 11:38:51 AM »
I think Tan Chong lost money seling you the Latio.    ;D
Jokes aside, I am genuinely surprised how your problem could keep reoccuring despite replacement of the defective part.
Offline Toalson
« Reply #15 on: August 11, 2009, 12:51:56 PM »
If replacement had taken placed, it would be reflected in the servicing record. If they cheat, they will probably be terminated from employment.
« Reply #16 on: August 11, 2009, 01:41:52 PM »
Ok. Seems that those with multi -storey carpark got this problem.  also try not to over steer too often . best to park at first level.  no need to go up too often
Offline rongshu
« Reply #17 on: August 12, 2009, 09:27:47 AM »
Sad, I started having this sound also recently after 30K. So now try not to turn steering too much. A bit disappointed with Nissan.
Offline pmet
« Reply #18 on: August 12, 2009, 11:23:57 AM »
Mine's basement car park, seems the latio steering is not able to take the fast spiral turning
Offline pest11
« Reply #19 on: August 12, 2009, 11:46:32 AM »
pmet: thanks
1st, SA need to access this "tok tok" sound, if SA cant find the problem, u do the driving and show them the problem.
with prior booking, maybe a ~2hrs job (*still subject to the crowd)
btw, Slphy also faced this problem.
